Samsung 70" 4k "bad panel"
  • scuby
    • Jan 2014
    • 33
    • netherlands
    Hello
    I have a 70" Samsung tv. It's a recent 4k model. Produced in 2020. It's barely 3 years old.
    At first it was stuck in a boot loop. Something was shorting to the panel itself.
    It has a power supply and an integrated t-con with a single ribbon connector to the screen which has three separate small driver boards interconnected by two ribbons.
    By process of elimination i deduced the lower right driver panel was the problem.
    By either covering a few pins i could get the tv to boot but the image had lines. While messing around I managed to success fully find a formula that worked to get a full 4k picture.:
    Start the tv with the offending driver disconnected. Reconnect once the backlight was lit up and sound playing
    After a try or two it would play for hours no problem. Try and restart and no go if you let the set rest longer than a few seconds.
    I took it to a tv repair shop who just did the bare minimum and said: it's your panel. I've found a few sources that point to a bad cap on the driver board
    Thing is now i can't get a picture anymore at all.
    I used contact cleaner on the ribbons only sound and the backlight. Did I fry something potentially with context cleaner? It boots every time now, sound and backlight but no picture. That's what it did when I disconnected the offending driver panel... I'm thinking it's not making propper contact anymore
    Hoping for advice to further fix this thing. Seems absurd to throw away
  • howardc64
    • Jun 2017
    • 634
    Re: Samsung 70" 4k "bad panel"
    Can you provide
    • Complete model #
    • Picture of entire back of TV showing how everything is connected
    • Pictures of main, PSU, and driver boards
    • Close up pictures of ribber cable contact pins and connectors
    • howardc64
      Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
      by howardc64
      • Prior owner tried a replacement main board. No difference.
      • Samsung 2x red blinking standby LED = panel fault
      • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
      • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
      • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
      07-19-2025, 10:54 PM
      09-07-2024, 05:50 AM
    • triplefour
      SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
      by triplefour
      TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
      tcon is built into mainboard.
      Only one cable goes to panel boards.
      there is a cable from one panel board to the other that links them.
      cost cutting measure that results in us having harder time to diagnose.
      removing the link to the second panel board allows TV to stay on with stable backlight but no image.
      used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
      07-28-2022, 07:59 PM
    • NWArkGuy
      Samsung UN65TU8000 - Panel Issue [ hole in ribbon cable ]
      by NWArkGuy
      Well, I will be the first to admit that I screwed up...
      In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
      I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
      I have 2 that I have found and have in my possession. ...
      10-12-2023, 10:13 PM
    • KYBOSH
      Samsung UN50TU8000 - Dead Panel Forensic Questions
      by KYBOSH
      I came across a 50inch TU8000 that wouldnt start up properly (blinking stand-by light, backlights would cycle on and off).
      When i opened it up and removed the power to the mainboard the backlights powered up and everything looked uniform.
      When reconnected the mainboard but disconnected the flex cable to the panel i heard the TV startup with the intro sound.
      Later I checked for shorts on the panel PCB boards but could not find anything.
      When I took a look with the FLIR i noticed the 2 resistors...
      08-10-2024, 08:39 AM
