Panasonic TX-40AS640E IC8901 dump needed
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4541
    • Italy - Milan
    Hi, i need memory content of IC8901 BR24G16 2kb
    thanks!
  • lotas
    • Jan 2016
    • 4905
    • Russia
    Re: Panasonic TX-40AS640E IC8901 dump needed
    Motherboard TNPH1077 1 (A)?
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4541
      • Italy - Milan
      Yes
      • lotas
        • Jan 2016
        • 4905
        • Russia
        Will 40ASR650 fit?
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4541
          • Italy - Milan
          The problem with this s*it tv is that i have started rgb screen test with the key combination as for service manual, now it never exit that mode, i strongly doubt that a settings eprom rewrite would solve this but i can't try something else, i don't know the model you say and if it fits.. i'm stuck in this situation since years..
          • lotas
            • Jan 2016
            • 4905
            • Russia
            Well, I don’t know, the motherboards are the same, apparently for different regions, the main thing is to save your own, if something goes wrong.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4541
              • Italy - Milan
              i already saved, if you want to provide me it, thanks "A LOTas"..
              • lotas
                • Jan 2016
                • 4905
                • Russia
                Try.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4541
                  • Italy - Milan
                  The test did not worked. May i rewrite the tcon ( 14Y_RA_EF12TA2MB4C2LV0.3 - LMC400HF07 - LJ94-29557E/D) eprom ice1 24c128
                  • re-atari
                    Anycubic Photon 5.5 3D printer 25Q32 flashrom dump needed
                    by re-atari
                    Hello all, as the title says, I'm very much in need of a valid firmware dump of a Anycubic Photon 5.5 3D resin printer. It's stored in a Winbond 25Q32, so it's 4Mbyte.
                    Here's a little background for my request. A few weeks ago I bought this 3D printer from a guy who had moved on to a PLA printer. I got it at a vey reasonable price, as it was in a defective state. The seller told me that he had experienced a power failure during a firmware upgrade, after which the printer appeared to be dead. He thought the firmware was corrupted in such a way that the printer was now bricked. As he...
                    02-03-2025, 06:49 PM
                  • rednix01
                    Nuc7i5BNH Bios Dump Needed
                    by rednix01
                    I accidentally bricked my NUC7i5BNH after disabling the option to boot from USB, and now it's not showing any display at all. I tried the USB recovery method, but unfortunately, it didn't work.
                    Local repair shops are quoting around $150 just to flash the EEPROM, but considering the unit is only worth about $75 these days, that’s not really an option. So I'm hoping to learn how to flash the chip myself. But to get started, I need a working BIOS dump for the NUC7i5BNH.
                    I did come across a post with a dump for the NUC7i7BNH, but I wasn't sure...
                    06-19-2025, 06:37 PM
                  • jorpec
                    Dump/Firmware needed TV Kunft 19CG86813 Board T.EME380.61 Panel ECG185BB-LC4
                    by jorpec
                    Hi, all
                    I need the dump/firmware for this tv, it was on a boot loop, i dont have the original corrupted dump because i used a pen drive with a firmware that solved the boot loop, initially it seemed it was ok but the tv has no sound
                    10-17-2025, 03:51 AM
                  • sedat88
                    Panasonic CF-54DY024NG Bios Dump
                    by sedat88
                    I'm looking for Panasonic CF-54 bios dump.
                    Flash memory with bios is damaged and is not possible to recover any information from it.
                    Model Name - CF-54DY024NG
                    S/N: 6DTSA61473
                    Thank You...
                    09-29-2025, 03:03 AM
                  • hirens
                    Lenovo ideapad 3 14IGL05 bios dump needed
                    by hirens
                    model: 81wh
                    sn: pf36ta6h
                    board no: nm-c961 gs453/gs553
                    hey guys above is my laptop info
                    it only blinks the power button kindly help me with a working dump
                    old dump attached...
                    07-21-2023, 04:48 AM
