Help with Bush Tv (Vestel 17mb95m Mainboard)
  • FlailingEngineer
    • May 2023
    Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
    Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...3d.html#manual).
    Now on to the actual problems I am facing. I have managed to connect the TV to my wifi network but casting youtube doesn't work; the app crashes every time it loads up, the same applies to Netflix. I have attempted to update software and firmware through the built-in menus however they are both the most recent versions (after doing a factory reset neither version number changed so I'm assuming they never pushed an update to begin with). The HDMI ports also do not work so purchasing a streaming device to handle the "smart" side of things isn't possible.
    Does anyone have any idea what the issue might be? I contacted Vestel and they basically said the TV was too old for them to be bothered about and to contact Bush support, which I'm guessing is just as helpful .
    I've been doing some digging and came across the Vestel Toolbox which I used to get telnet access to the TV but FTP doesn't set up. I don't have a spare usb stick on hand at the moment to get any data on/off the TV but as soon as I do I will. I'm not even sure if this is a soft issue to begin with and I may just have to replace the board altogether.
    Speaking of which, are there any newer compatible vestel boards i can swap with mine to maybe get some better firmware/built-in useability? I'm not that bothered anyway, my current plan is to stick KDE Plasma Big Screen on an old laptop and just use the display, so as long as I can get the HDMI ports working I'll be content.
    Oh and before I forget, I had a look at the diagnostic menu and HDCP 2.0 status was NOK. Not sure if that makes any difference but just thought I'd give as much information as possible.
    Any help/information would be greatly appreciated, all I've got right now is a really crappy mirror since I don't watch digital/analog TV.
    Many thanks, FE
  • thommyX
    • Apr 2016
    • 93
    Re: Help with Bush Tv (Vestel 17mb95m Mainboard)
    The device is probably built in 2012 and unfortunately no longer designed for the Internet. Unfortunately, another mainboard doesn't work. The panel data must be right and this is only possible with the original mainboard.
    Thomas
    • FlailingEngineer
      • May 2023
      Thomas
      So my best bet to revive the TV would be to replace the mainboard and make use of HDMI ports?
      thanks for your help
        • 31015
        all "smart" tv's are spying advertisement-delivery devices.
        just get a good tv and link it to a raspberry pie type device stuck behind it.
        • samtron123
          Vestel 17MB95M Mainboard LVDS Chip?
          by samtron123
          Hi
          Vestel 17MB95M mainboard LVDS chip Q33 has no power ??
          Can anyone help me?
          many thanks
          03-01-2021, 04:42 AM
        • porfyriadhs
          Vestel 17mb230 mainboard.No Sound
          by porfyriadhs
          Hello to everyone . I have a vestel mainboard 17mb230 with no sound on the speakers only on the headphones . I think that hotel mode is on but I cant find a way to fix .. Any help will be good thanks
          03-19-2024, 01:12 AM
        • KevinWysocki
          Aya A39FHD3901/2 - Vestel 17MB82 mainboard - LED blinking
          by KevinWysocki
          Hi there,
          My mother in law gave me an Aya TV, to take a look if I could do something to repair it.
          At startup, LED constantly blinks and no image is shown (even if I light the screen, broken backlight is not the problem), also +12V power rail is fine.
          After some research, it seems that NOR flash often fails on this mainboard, I have found the procedure to force flash upgrading with a USB key connected to mainboard USB port, pressing "OK" button on the remote and plugging the TV power cord.
          Flash upgrade didn't seem to work,...
          08-20-2023, 09:45 AM
        • Aivar1988
          Can I use different VESTEL panel on mainboard?
          by Aivar1988
          Is it possible to replace any part at all in a Vestel TV with a slightly different part?
          For instance a screen panel - VES650QNTB-2W-U11 <-> VES650QNTS-2D-U11
          Or a mainboard 17MB130P for any other 17MB130P as long it had the same screen size or even the same screen panel? For example I have a 65" JVC and can I replace it with a 65" Telefunken or Hitachi mainboard. Will I need the new remote aswell? And is it possible to install the JVC firmware onto the new mainboard later?
          09-14-2021, 12:55 PM
        • Bazilwrc164
          Request: Firmware for Hitachi 42HXT12U (Vestel 17MB95M, VES420UNDL Panel)
          by Bazilwrc164
          I’m looking for a USB firmware file or EEPROM dump for a Hitachi 42HXT12U TV.
          The mainboard is a Vestel 17MB95M, and the screen panel is VES420UNDL.
          I recently replaced the mainboard with another 17MB95M, but it’s programmed for an LC420DUJ panel, and I’m getting no picture. I’d like to flash the correct firmware via USB or update the EEPROM if needed.
          If anyone can provide:
          • A working USB firmware file (like upgrade_loader.pkg or mb95_m.bin)
          • Or a compatible EEPROM dump
          07-23-2025, 12:15 PM
