ltv 32w6 westinghouse tv/monitor no power steady blue light
  • magus123
    • Sep 2010
    I purchased this tv at a yard sale for cheap
    i have repaired several lcd monitors and what to start on tvs
    my knowledge is at only repairing bad caps. no real electrican experience.
    what it does :
    i plug the power cord into the tv . nothing happens yet
    press the power button . steady blue light comes on. at the same time
    the speakers also make a sound and then gos away.
    the screen is complete black . no menu or etc.
    tried the flashlight trick and nothing is visible on screen.
    opened the unit up and all capicitors look fine . i should mention the tv uses
    quality rubicon caps. nothing looks bad. ive check all components and everyting seems fine.
    i have only $20 dollars invested and i am well aware of the bad quality of these tvs. has anyone ever played with this time of problem or can tell me where to start.
    i can only assume that the fuse is ok . as when i turn on the tv the blue light turns on and stays a steady blue.
    1. to double check how do i test the fuse . multimeter procedure
    2. where would you start troubleshooting.
    3. any known problems with these units . ive researched everywhere and cant find any person that has worked on these units. the only hint i get is that the power supplies go bad.
    4. should i start replacing caps?
  • PlainBill
    • Feb 2009
    • 7034
    Re: ltv 32w6 westinghouse tv/monitor no power steady blue light
    I wouldn't start replacing caps just yet. I haven't had a lot of luck with the flashlight trick myself. There are a couple of ways to narrow down the possibilities. The first is to hook up a signal source (DVD player, video game, etc) and step through the inputs and see if you can hear anything from the speakers. If you can, that is an indication the power supply is probably working. If the outputs of the power supply are labeled, use a dmm and verify the voltages are correct. Also, there are a couple of failures of the inverter that will result in either a very brief flash, or no flash at all. I always suggest turning the TV on in a darkened room and watching from the back (ideally with the back removed) for any sign of a flash.
    Beyond that, my signature contains links on attaching pictures. I have found that one overall shot of the back of the TV, plus one of each board gives us the starting point for assisting troubleshooting. Don't forget to provide a picture of the inverter.
    PlainBill
    • magus123
      • Sep 2010
      thank you.
      once i do those tests and get good pics ill post back
      • Tvbob
        tvbob
        • 204
        your Westinghouse tv has lost its (firmware) on the main module
        there is no way to re flash it via the service port, you have to change the board
        • MOSSEP
          Monitor Audio RSW12 - Green light but no audio
          by MOSSEP
          Hi
          Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
          Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
          The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
          I have already tried replacing all of the...
          01-26-2025, 08:18 AM
        • usbdevice
          Acer X223HQ (Version Bbd) on/off-power-cycling
          by usbdevice
          Hi all
          There's two other threads about this monitor with seemingly the same problem. The problem was resolved in one case by replacing the entire PSU board and in the second one by replacing an unknown IC.
          https://www.badcaps.net/forum/showthread.php?t=50657
          https://www.badcaps.net/forum/showthread.php?t=40512
          The first one has pictures of the pcbs and I noticed that there's one IC and assorted caps not populated on mine (but the PCB itself looks identical) so I thought that'd warrant a new thread.
          It's my dad's old monitor. He...
          08-05-2022, 02:21 AM
        • MOSSEP
          Monitor Audio RSW12 - Green light, but no sound
          by MOSSEP
          Hi
          01-26-2025, 08:33 AM
        • Tomylee
          Nintendo 2DS XL – Orange light, no blue light, signs of overheating
          by Tomylee
          Hi everyone, I have a Nintendo 2DS XL that shows the orange charging light when plugged in, but nothing happens when I press the power button — no blue light, no screen, no sound.
          Here's what I've observed:
          All ribbon cables are properly connected
          Battery is present and in good condition
          No reaction even with screens disconnected
          There's a visible burn mark / overheating sign on the metal shield, right above the CPU
          I’m suspecting an issue with the CPU, PMIC, NAND, or a power...
          06-26-2025, 02:33 PM
        • valscu
          EIZO SW3031W monitor blue color instead of black
          by valscu
          I have an Eizo SX3031W monitor and after a period i had problems with the tcon board. I did reflow, it went well for a while after but the problems appeared again. The second reflow attempt was a failure, the tcon board stopped working. In the meantime, I bought a perfectly functional Samsung 305T monitor from which I took the tcon board and installed it in the Eizo monitor. Since I turned on the monitor, the blue color appeared in the background instead of black. And also in Windows, appears blue instead of black. I tried various settings from the monitor and driver settings but...
          08-10-2022, 02:08 PM
