Zenith Z50PJ240 - White Screen with 'Power Only' displayed
  • cmonkey
    • Apr 2023
    • 58
    • Unitied States
    Turned on my lovely plasma and after about 30 seconds the screen below showed up. None of the inputs are responsive, just the red light flashes when I push it. Remote doesn't work either. To turn it off I need to unplug it and when I plug it in again it turns back on to this screen.
    I only found one reference to this issue with a different model but it didn't look super reliable. Only mentioned a 'main board fault'. The main board for this one is on ebay for $34 so might need to go with that.
    Anyone seen this before?
    Thinking about it some more, it happened right as I pushed the wrong button on the remote I use for this TV. It's not a Zenith remote. I pushed the 'open/close' button on the remote instead of the 'input' button and it immediately displayed this message. Maybe it's a coincidence, but I did find this which talks about universal remotes causing issues for LG tvs. Zenith is owned by LG.
    EDIT - So I fixed this issue by simply pushing the 'Exit' button on the remote I have. It's not a universal remote, but it's also not a Zenith remote. But it worked!! So this post is just for anyone in the future who might encounter this weird situation.
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • reformatt
    by reformatt
    07-31-2025, 08:37 PM
  • smic717394
    by smic717394
    07-25-2024, 10:16 AM
  • Chrissygizmo
    by Chrissygizmo
    02-10-2025, 12:33 AM
  • ipatch
    ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
    by ipatch
    i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
    08-24-2024, 02:36 PM
