Samsung UE40MU61 no red led but backlight
  • kevvort
    • May 2023
    • 10
    • Italy
    Hi all!
    I've a Samsung UE40MU61 that's not showing the red led when it's in stand-by nor turns on.
    I diagnosed the power board and looks like it's fine + if I disconnect the main board all the panel backlights turn on so I suppose, based on what I've found, that the power board should be ok.
    Then I moved to the main board BN41-02568B and after some googling I've found this forum where a lot of people reported that the issue could be in the FW contained in the W25Q40CL chip.
    I got my reader and dumped it but it doesn't look like it's corrupted because there's data in the first 0x1000 addresses.
    I also checked the joystick and voltages are ok but the red led voltage is totally missing.
    Do you have any tip for me? For being sure I'll attach my dumped firmware.
    Thanks a lot
  • lotas
    • Jan 2016
    • 4880
    • Russia
    Re: Samsung UE40MU61 no red led but backlight
    What a strange Dump you have, it looks like a Dump from T-con (25Q80), you didn’t accidentally mix up the chips.
    • kevvort
      • May 2023
      • 10
      • Italy
      You were absolutely right, my bad... here as attachment my 1604 dump with a lot of FF in the first areas
      Just for curiosity: do you just restore the first 0x1000 addresses or do you do something else?
      • lotas
        • Jan 2016
        • 4880
        • Russia
        Try it, do not forget about the Status Register, but I restore the "header" with the correct version of the software.
        • kevvort
          • May 2023
          • 10
          • Italy
          Got it and ok about the status register, I did it.
          Now the red led is on, I can turn on the TV but I've a black screen with backlight, then looks like it bootloops.
          Any tips?
          • lotas
            • Jan 2016
            • 4880
            • Russia
            Well, maybe they damaged or incorrectly, somehow they recorded a dump in 25Q80 (you didn’t do anything with it?).
            • kevvort
              • May 2023
              • 10
              • Italy
              Well, maybe they damaged or incorrectly, somehow they recorded a dump in 25Q80 (you didn't do anything with it?).
              Unfortunately yes, I tried to restore the content but it's a 25Q80 and I dumped it as a 25Q40 so I miss half the data
              Are IC1604 and 1603 coupled? I think I can at least try to find a IC1603 dump and merge the first half with mine but I need to be very lucky...
              Do you think it's the best thing I can do other than beating my head?
              • lotas
                • Jan 2016
                • 4880
                • Russia
                Now you need to look for exactly the same dump 25q80 that was originally, it contains all the settings and data of your panel, what is the number of your panel?
                And the full model of the TV itself and the motherboard number BN94-xxxxx?
                • lotas
                  • Jan 2016
                  • 4880
                  • Russia
                  These are completely different dumps, and each is responsible for his own, and there is nothing to combine in them, there is no need to cross.
                  • Diah
                    • Feb 2013
                    • 6593
                    since TV go to STB and turn on... all other issue can be solved by service menu call from STB
                    • kevvort
                      • May 2023
                      • 10
                      • Italy
                      TV full model: UE40MU6120KXZT
                      Board: Code: BN41-02568B
                      MODEL: BN41-02568B
                      MOEDL: KANT_M_BUILT_IN
                      So every dump should work or are there any keys that should match with other components?
                      • lotas
                        • Jan 2016
                        • 4880
                        • Russia
                        What is the service menu if it completely killed the dump T-CON.
                        • lotas
                          • Jan 2016
                          • 4880
                          • Russia
                          MODEL: BN41-02568B
                          I need the number not BN41-xxxx, but the number BN94-xxxxx (it is on a white tag pasted on the motherboard), and I asked for the number, panel (matrix) model.
                          • Diah
                            • Feb 2013
                            • 6593
                            T-CON are for freq rate displaying.. S;M are simple rate don't depend on any high resolution T-CON support
                            • lotas
                              • Jan 2016
                              • 4880
                              • Russia
                              In these models, if the dump T-CON (25Q80) is damaged, then there will be no image, only the backlight!
                              • lotas
                                • Jan 2016
                                • 4880
                                • Russia
                                kevvort try dump 25Q80
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4542
                                  • Italy - Milan
                                  Hi, can you explain to me better? You have read the tcon memory as a 25Q40, after this you noticed was the wrong memory, so you haven't write any thing on that right? If this is the case you probably has a fault in the panel..
                                  • kevvort
                                    • May 2023
                                    • 10
                                    • Italy
                                    Thank you Lotas, it worked!
                                    Now I'll test deeper if everything is fine but I think I'm ok.
                                    • dex1
                                      • Jul 2012
                                      • 7
                                      • friuli
                                      Sorry, I'm new to these Samsung memories. What do you mean by status register and header?
                                        09-07-2024, 05:50 AM
                                      • C152Heavy
                                        Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
                                        by C152Heavy
                                        Summary for TL-DR readers:
                                        • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
                                        • Have obtained Samsung schematic & service documents - Can upload if helpful.
                                        • Have read ALL applicable threads
                                        • C1818 and CP820 replaced as low hanging fruit
                                        • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
                                        • VCC pin (18) of PFC...
                                        01-11-2023, 02:53 PM
                                      • sansanpartida
                                        Samsung QE82Q70RAT no backlight
                                        by sansanpartida
                                        Hi everyone!
                                        Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
                                        My issue: No backlight.
                                        Model: QE82Q70RAT
                                        Type No: QE82Q70RAT
                                        The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
                                        So hopefully, I can fix this cheaper.
                                        05-22-2024, 06:56 AM
                                      • howardc64
                                        Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                                        by howardc64
                                        TV was fixed just after removing Samsung's rear snap cover.
                                        This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                                        Maybe PSU->backlight connector didn't have a good contact?...
                                        07-23-2025, 12:34 AM
                                      • howardc64
                                        Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                        by howardc64
                                        • Prior owner tried a replacement main board. No difference.
                                        • Samsung 2x red blinking standby LED = panel fault
                                        • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                        • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                        • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                        07-19-2025, 10:54 PM
