Samsung QN55Q80R Bad Panel Help
  • Storyteller12
    • Jun 2020
    • 625
    Got this tv and it would reboot with no picture when I got it.
    Unplugged mainboard from power supply and all leds light up and stay on.
    So I try tape method and got the tv to stay on and not rebooot but no picture.
    If I cover just the 1st pin on lvds cable the tv and backlight stay on just no picture.
    I've tried every combination of pins to cover and can't get a picture for nothing.
    Just curious if anyone else has this problem with this model and found a solution?
    Any suggestions or help would be appreciated.
    I circled the lvds cable that I taped and marked the side of the cable that I covered with tape on the first pin to get it to stay on.
  • Diah
    • Feb 2013
    • 6562
    Re: Samsung QN55Q80R Bad Panel Help
    could you upload close focused photo on the other LVDS socket ( the top one ) at main board
    • Storyteller12
      • Jun 2020
      • 625
      Here you go. Let me know if you need me to remove heatsink.
      • Diah
        • Feb 2013
        • 6562
        remove yours masking on other LVDS which you did... and try this exact pins masking at MB side...
        • lotas
          • Jan 2016
          • 4855
          • Russia
          Install the jumper, and now you can experiment - disconnect the left and right bars in turn.
          • Storyteller12
            • Jun 2020
            • 625
            Ok tried those pins and the tv just reboots again with no image
            Also tried with the 1 pin I had covered and the pins you asked me to cover and tv stays on but no image
            • Storyteller12
              • Jun 2020
              • 625
              I will try this now but can you explain what this does by jumpering them. Just trying to understand what I'm doing.
              • Diah
                • Feb 2013
                • 6562
                no boot loop doesn't mean any.... you need to approve if you have sound.
                • Storyteller12
                  • Jun 2020
                  • 625
                  Lotas, with that jumper and 1 of the lvds cables unplugged I got image on half the screen.
                  • lotas
                    • Jan 2016
                    • 4855
                    • Russia
                    Yes, it should, now you know which half is not working.
                    • lotas
                      • Jan 2016
                      • 4855
                      • Russia
                      With this jumper, T-CON thinks that you have two cables connected, and gives signals to the panel, if you disconnect any cable without a jumper, nothing will happen.
                      • Diah
                        • Feb 2013
                        • 6562
                        from my test was also should show complete screen.. but as he said no change / no boot i think you have some where on this half broken glass of LCD... take out the bezel and inspect the courmers
                        • Storyteller12
                          • Jun 2020
                          • 625
                          Ok, I got a full image but the picture is washed out and not really acceptable.
                          Diah- you weren't far off as the pins I covered were right where you pointed me. Just a few off I believe.
                          • lotas
                            • Jan 2016
                            • 4855
                            • Russia
                            Try another + 2 pin.
                            • lotas
                              • Jan 2016
                              • 4855
                              • Russia
                              Then check SPI Flash is not shorted.
                              • Storyteller12
                                • Jun 2020
                                • 625
                                I’m gone for the day but will check tomorrow and report back.
                                • Diah
                                  • Feb 2013
                                  • 6562
                                  rubbish Samsung... why people buy this trash
                                  • Storyteller12
                                    • Jun 2020
                                    • 625
                                    You make me laugh. So true, but unfortunately there is really no good tv to buy these days. Seems like they're all crap. If not Samsung your just buying another pieces of shit from another brand.
                                    • Storyteller12
                                      • Jun 2020
                                      • 625
                                      Update, I tried covering those 2 pins as well but no luck. Same washed out image.
                                      Also checked both winbond chips and neither are shorted and I measured 3.3v on vcc.
                                      • lotas
                                        • Jan 2016
                                        • 4855
                                        • Russia
                                        Sometimes it helps to reduce the VGH voltage on the non-working side.
                                        The TVS diodes on the bar were measured with a multimeter for low or short resistance.
                                        • howardc64
                                          Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                          by howardc64
                                          • Prior owner tried a replacement main board. No difference.
                                          • Samsung 2x red blinking standby LED = panel fault
                                          • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                          • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                          • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                          07-19-2025, 10:54 PM
                                          09-07-2024, 05:50 AM
                                        • maneatingmonkey
                                          Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                                          by maneatingmonkey
                                          I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                                          There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                                          03-27-2024, 07:17 AM
                                        • stylishconsultant
                                          un60j620dafxza - Samsung No Display Problem
                                          by stylishconsultant
                                          Hi All,
                                          Need help.
                                          I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                                          So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                                          problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                                          might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                                          09-04-2024, 03:26 AM
                                        • NWArkGuy
                                          Samsung UN65TU8000 - Panel Issue [ hole in ribbon cable ]
                                          by NWArkGuy
                                          Well, I will be the first to admit that I screwed up...
                                          In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
                                          I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
                                          I have 2 that I have found and have in my possession. ...
                                          10-12-2023, 10:13 PM
