Viewsonic 32" lcdtv - should i buy it?
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    ok so the technology recycler/computer repair shop i work at got in a viewsonic 32" lcdtv. (not exactly sure of model since im at home at its there.
    i could probably get it for cheap, because even though it works there is one problem. the problem is that if you just give the power button a normal psuh, the power led will blink for a second.
    but if you hould it down for like 10 seconds, then it will llight up (bright), then a few seconds later the led will dim down as the screen turns on. then it works fine (i havnt left it on longer than 2 mins but i think it wil then just stay on. the person who fixes lcds at renew computers (the name of where i work), he said that he says if its ok with the boss i could have it for cheap cu even though he says its probably just a bad startup cap on the power board he doesnt wnna bother with it cuz he is busy with a few other projects right now. so woul it be a wise inveestment to buy it then see if there are obvious blown caps?
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Viewsonic 32" lcdtv - should i buy it?
    I'd buy it. But depending how cheap "cheap" means.
    A working TV? How boring!
    • retiredcaps
      • Apr 2010
      • 9271
      Ask if you can open/inspect it first before buying. If it is obviously bad caps, then you may want to go for it.
      If it is not obviously bad caps, then be aware that troubleshooting and repairing LCD and plasma TVs are an order of magnitude more difficult then computer LCD monitors.
      It seems to me that much of the troubleshooting of LCD and plasma TVs are more about board replacements versus component repair (like bad caps or transistor). Additionally, you may be sourcing boards from ebay and dubious sellers.
      In Canada, 2 local vendors had an one day "blowout" sale on Saturday. 50 inch 720p name brand plasmas like Samsung were being sold for $548 CDN (1 year warranty). So just keep that in mind to help make the decision and how much money you spend fixing an old one with no warranty.
      --- begin sig file ---
      --- end sig file ---
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        Less than $100
        • PlainBill
          • Feb 2009
          • 7034
          Viewsonic TVs are not highly regarded due to a lack of quality.
          The guy is probably right - capacitor problems. If you can open it up and verify bulging caps $100 is a fair price. If you can't, maybe half that would be safer.
          PlainBill
          • shovenose
            Send Doge Memes
            • Aug 2010
            • 6575
            Ok. But i always thought samsung, lg, and viewsonic were good quality. Then i came here and learned that samsung is bad. But imo viewsonic is good?
            How would a better tv be built differently than a viewsonic (not talking about picture quality)
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              beat em up real good on the price.
              its most likely caps.i see a bunch of viewsonic tv's here with bad caps.iirc the only one that was not caps had a cracked panel.
              • lostone
                Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                by lostone
                Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                05-19-2024, 11:40 AM
              • StefanNg
                Viewsonic VX2718-PC-mhd SG2701B01-8
                by StefanNg
                Hi, Badcaps.
                I am troubleshooting a monitor
                Viewsonic VX2718-PC-mhd.
                Panel model SG2701BSG2701-8
                Symptoms is no image.
                This panel has 2 panel board connected by a U-ribbon.
                When I disconnected the ribbon, I get a perfect half screen image.
                I took some test point voltage, when ribbon disconnected.
                HVAA 8.38v
                FVDD12 1.21v
                FDD33 3.3v
                VIN 11.79v
                VAA 16.85v
                VGHF 30.16v
                VGL -8.02v
                CK1_I ~ CK8_I 1.403v
                CK1_L ~ CK8_L 8.26v
                When I connect both panel board
                HVAA, VGHF, and CKx_L...
                05-17-2025, 01:43 AM
              • Fagauthier
                Viewsonic power supply model #EADP-64BF B Need circuit diagram…
                by Fagauthier
                I have à defective Viewsonic monitor. I can't find a circuit diagram for it' power supply.
                Model #EADP-64BF B
                The user manual have all diagram except for the power supply. I would appreciate help to find the circuit diagram, thanks...
                07-08-2023, 08:02 PM
              • Returning Buick
                Viewsonic G810 vertical deflection problem
                by Returning Buick
                I have a G810 monitor i've had for years but it has developed a problem with vertical collapse. Is there anybody here who has worked on these and can help me find where the circuit even is for the vertical deflection?
                04-01-2025, 07:57 PM
              • RetroComputingGrotto
                Viewsonic VA2010wb (High Pitch Squeal At Power On)
                by RetroComputingGrotto
                I've got a monitor on my workbench at the moment that makes a high pitch squeal (that I cant hear as my ears are too old) when you power it on and lasts a couple of seconds before quitening and apparently it can be heard at regular intervals whilst on.
                On opening up the monitor and looking at the PCB the usual suspects showed their heads so I have already replaced all the electrolytic capacitors.
                The other issue that was reported with this monitor was the fact it took ages to start displaying anything after pressing the power button.
                What component(s)...
                02-03-2025, 06:00 AM
