Hi . I have emmc KLM4G1FEPD from mainboard Samsung tv set in boot mode status . I can't reflash firmware in this ic .I have done succesfully new firmware in other Samsung emmc - for example - KLMAG1ENB , or KLM4G1FEAC , but with KLM4G1FEPD both my tools - UFI and Z3X can't reflash .UFI and Z3X reading firmware succesfully .I am not sure - TP point is correct .Maybe someone knows TP is correct ?
KLM4G1FEPD - boot mode
by privato89Hello everyone,
I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
Let's begin:
Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the... -
by TheUserHello to everyone ,
This is my first post here, and i would like to share with you a small story in case you can help me.
Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help... -
by hinisaI'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...-
Channel: Troubleshooting & Designing Networks
by zklgfsHi,
I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...-
08-11-2025, 02:14 PM -
by Luke AndersHi everyone,
A few details about the laptop itself:
Name: Lenovo Legion 5
Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
BIOS Version: GKCN60WW
EC Version: GKEC65WW
Serial Number: PF39AQ7Z
Board Model: NM-D562 Rev 3.0
RAM: 16GB Installed, DDR4 (brand new)
NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
I bought this laptop recently from eBay as a faulty device.... - Loading...
