Toshiba 32D1333B <Firmware needed>
  • StephenU
    • Dec 2013
    • 230
    • United Kingdom
    Afternoon all I'm wondering if someone has, or could point be in the direction of the correct firmware for the above TV please?
    Mainboard:
    10081192 230724227 457 32"
    27007279 SDILTA320AP33 GB
    V214j3_MB95S(T0S)
    TV turn on/off, green LED flashes tv turn on then off. No rhyme or reason done some research after changed the backlights that its most probably the firmware on the mainboard.
    Any help would be appreciated. thanks
  • yokoono
    • Apr 2010
    • 481
    Re: Toshiba 32D1333B &lt;Firmware needed&gt;
    Panel VES315WNDL-01 ???.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Need to replace whole spi and dump onto new Ic, otherwise it will fail again. I don’t bother with mb95’s and more. Swap it for mb82
      • StephenU
        • Dec 2013
        • 230
        • United Kingdom
        Panel is a : LTA320AP33
        • StephenU
          • Dec 2013
          • 230
          • United Kingdom
          Originally posted by ReeceyBurger123
          Need to replace whole spi and dump onto new Ic, otherwise it will fail again. I don't bother with mb95's and more. Swap it for mb82
          Thanks for this mate, could you let me know a compatible board for this, if possible please?
          Rgds,
          S.
          • StephenU
            • Dec 2013
            • 230
            • United Kingdom
            Guys can I use any mains that uses LTA320AP33 screen, or does the TV model need to be exact also. I have managed to source a 32W1333D mains. Thanks for your time and patience.
            S.
            • yokoono
              • Apr 2010
              • 481
              I have for programmer (flash memory). Is good ?.
              • StephenU
                • Dec 2013
                • 230
                • United Kingdom
                Originally posted by StephenU
                Thanks for this mate, could you let me know a compatible board for this, if posssible please?
                Rgds,
                S.
                • StephenU
                  • Dec 2013
                  • 230
                  • United Kingdom
                  So am I right in saying the SPI chip is bad and the firmware is fine?
                  Ultimately I could remove SPI read and save - then write to new SPI chip?
                  Thanks RB123
                  • Diah
                    • Feb 2013
                    • 6363
                    dont play with spi..... yours tv turn on and off and panel spec saved on it... just play other part of firmware with out mboot. you will be fine.. search over here i upload time ago firmware with out mboot.
                    • StephenU
                      • Dec 2013
                      • 230
                      • United Kingdom
                      Thanks I will keep looking.
                      • StephenU
                        • Dec 2013
                        • 230
                        • United Kingdom
                        Short update on thread, ordered the 32W model mains and everything worked fine, so I have removed SPI and sent it to be read and wrote to new IC. Will update thread when I have the part back and fitted.
                        Thanks for the help as always.
                        S.
                        • StephenU
                          • Dec 2013
                          • 230
                          • United Kingdom
                          UPDATE
                          Got the new SPI back flashed with the firmware from the old IC, but TV still has the same issues. I have put in the 32W1333D mains in for now as it works fine with this. Just need to use without DVD function.
                          Thanks for all the input.
                          rgds
                          S.
                          • cheeky2
                            Toshiba 49U7763DB (Mainboard: Vestel 17MB120) firmware issues after sporadic power cu
                            by cheeky2
                            I have this Toshiba 49U7763DB Tv which was suffering issues after various electrical power cuts, which happened in quick succession
                            Originally the TV was powering on and then very shortly powering off. I managed to get into the menu structure before powering off and carry out a first time installation of the TV. Which didn't make much difference. I have managed to factory reset (that didn't make any difference either).
                            The firmware inside the 17MB120 is corrupted and is causing some strange issues so my question is does anyone have any suitable firmware for this model?
                            Details:...
                            08-17-2023, 04:34 AM
                          • anlu
                            Vestel Firmware - Toshiba 32W133DN
                            by anlu
                            Hello, i have an old Toshiba 32W1333DN (sorry, misspelled the headline) TV that had the standby led green/red flashing and no lightup problem, i repaired it by measure the led output as suspect led problem, i measured the LED:s one by one and found one bad led, i replaced the the led-straps and the TV works.
                            Now i need to update the software because the new rc "RM-L890" does not work and i think maybe it could be an firmware issue?, i have struggled to find it without any success because all of the links where invalid, i contacted Toshiba but they do not support this model...
                            02-04-2023, 12:59 AM
                          • DarrenHD
                            Firmware for older Toshiba TV 22CV100U
                            by DarrenHD
                            HI all, Does anyone know if there exists an archive for older firmwares for Toshiba TV's? I've searched all over Toshiba's various websites and also on Dynabook's site (they say they deleted all old firmwares due to "server space". ) Toshiba has not replied to my request.
                            I'm looking for Firmware 1.07 for the 19/22/26/32 C100U series as described in this link:
                            https://support.dynabook.com/support...tentId=2865076
                            Thanks!
                            06-16-2025, 11:56 AM
                            09-06-2024, 05:27 AM
                            09-06-2024, 05:59 AM
