Philips 55PUS7363/12 Panel defekt or ? Help
  • markolino
    • Mar 2020
    • 109
    • Slovenia
    purely from a beautiful peace.
    I turn on the TV one morning and it shows like this..
    watch the video..
    please can someone help me. is it possible how to fix this??
    Link youtube:
    https://youtu.be/WVmXj3XmTUg
  • CurtisC
    • Mar 2023
    • 16
    • US
    Re: Philips 55PUS7363/12 Panel defekt or ? Help
    I am really new to this so I may be looking at it from the wrong way but using the troubleshooting guide it looks like a possible bad T-Con board.
    https://www.badcaps.net/forum/showthread.php?t=25810
    Does it do it on all inputs and picture settings?
    • markolino
      • Mar 2020
      • 109
      • Slovenia
      if anyone knows anything more, please write.. because there are also masters here on this forum.
      • diif
        • Feb 2014
        • 6978
        • England
        Please note this thread. https://www.badcaps.net/forum/showthread.php?t=39740
        • lotas
          • Jan 2016
          • 4842
          • Russia
          watch the video..
          Link youtube:
          Most likely this is the same problem, see these topics.
          https://www.badcaps.net/forum/showthread.php?t=118339
          https://www.badcaps.net/forum/showthread.php?t=118195
          • markolino
            • Mar 2020
            • 109
            • Slovenia
            Ok thanks..
            • bohaboha
              PHILIPS 32pfl3403d Flat-panel TV Upgrade Assistant problem
              by bohaboha
              Hi trying to update my Philips cause in retail mode not possible to get out from it i get this message in update site : Error message: no data exception. Your reference: Request ID (server_1930105)
              how to fix it thanks
              02-05-2025, 09:23 PM
            • Guerilla3
              Philips 32PFH4101 - bad panel?
              by Guerilla3
              Hello guys, I need your opinion whether this panel is bad and should I pursue it further. Third photo: left side t-con cable disconnected.
              11-22-2024, 12:54 PM
            • howardc64
              LG 49UJ6500 LCD panel lighter band that goes away
              by howardc64
              49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
              Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
              02-19-2023, 12:13 AM
            • triplefour
              SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
              by triplefour
              TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
              tcon is built into mainboard.
              Only one cable goes to panel boards.
              there is a cable from one panel board to the other that links them.
              cost cutting measure that results in us having harder time to diagnose.
              removing the link to the second panel board allows TV to stay on with stable backlight but no image.
              used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
              07-28-2022, 07:59 PM
            • Storyteller12
              QN55Q60R Service Menu Panel Help
              by Storyteller12
              I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
              I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
              I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
              the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
              01-13-2024, 01:57 PM
