Samsung UE49MU7470U LED backlight issue causing shadow?
  • Donny2derby
    • Apr 2023
    • 228
    • Uk
    Hi all. So from the knowledge I've picked up so far I believe the issue maybe caused by a failed strip of LED's? Looking at the photos would that be plausible?
    Secondly. How in gods name do you get access to the backlight panel? Mother of god
    I've tested the voltages with the tv powered up on the terminal rail marked CNL 802 and they're as follows reading from pin marked (A) upwards. Pin to ground.
    Pin A 298v DC
    298v DC
    0v DC
    216v DC
    216v DC
    0v Dc
  • Diah
    • Feb 2013
    • 6439
    Re: Samsung UE49MU7470U LED backlight issue causing shadow?
    yes its LED back light issue at the left side... few LED burned, but not only this..because the LED are edge strips .. mean the first reflection plate surface burned too because dummy Korean put it so close to touch LED surface
    you need to take out the panel.. and all filter sheet under it to have access to this LEDs... look on youtube there are so many video
    • Donny2derby
      • Apr 2023
      • 228
      • Uk
      I’m so glad someone like you has responded to confirm my findings Diah!
      In your opinion is it a relatively easy and not too complicated job to fix this? Is it worth it economically as well? What will be the cost of replacing the LED’s? Are they available to buy readily and cheaply? Will I have to buy a new reflective plate as well?
      Do you know the part number of the LED’s I need to buy? I’d rather buy them and have them ready to change before taking the screens apart so I can go about swapping them straight away and then put it all back together in one go.
      Thanks.
        • 12276
        • U.S.
        Probably something like this, just don't try to go along as fast as this guy does, he's done it before: https://www.youtube.com/watch?v=xwxfWPuwImE
        https://www.youtube.com/watch?v=x_xEGjyaYxM
        • Donny2derby
          • Apr 2023
          • 228
          • Uk
          Wow. That's a serious amount of work. Particularly when I'm not accustomed to something like this. I don't own suction pads so that's going to set me back £25 or more!
          I appreciate we all have to have a learning curve but this seems like a lot of effort for something I'm not guaranteed to see a return on!
          How much would these LED's and screens cost to replace and what could I realistically expect to sell the telly for once repaired?
          Thanks.
          I think I'll change my username to nomoresamsungs!
            • 12276
            • U.S.
            "I think I’ll change my username to nomoresamsungs!" If I could have 2 names, I would get that one, lately samsung does win for the shittiest name brand tv.
              • 12276
              • U.S.
              Check some of the techniques on youtube for screen removal, some do not use suction cups because they can suddenly just let go and the screen can break and other various reasons, it's the biggest job in tv repair but it's not really that bad, notice how quickly the guy gets thru it on the videos, of course he's done it many times, the strips aren't too bad to buy, need to get them from someone with good feedback, probably lots on ebay. Not sure what tvs are going for in your neck of the woods, here's a sample on ebay U.K.: https://www.ebay.co.uk/sch/i.html?_f...Condition=3000
              • Diah
                • Feb 2013
                • 6439
                Thanks.
                its not easy task to one who never did it before,,, also it will coast on you and you will never find the reflector plate any where.. sell it on ebay since it displaying picture.. at least you will earn money instate if the screen break down under yours hand,, never buy Samsung U again
                • Donny2derby
                  • Apr 2023
                  • 228
                  • Uk
                  Thanks Sonys. Your help is massively appreciated. I appreciate everyone who tries to help me but you have been particularly helpful to me each time I've posted so huge thanks to you mate!
                  I've looked into the cost of the make and model and think I can make something back on this even if it's gonna cost me a few quid to buy some gear to help me remove the screen and and also replace the LED's.
                  Will the part numbers for the LED's be on them or somewhere on the panel or are they a generic size for that size of telly?
                  Thanks.
                  • lotas
                    • Jan 2016
                    • 4753
                    • Russia
                    Maybe all the same your model is not ue49Mu7470u, but ue49Mu6470u, then your backlight with the number is BN96-39674A.
                      • 12276
                      • U.S.
                      Part numbers should be on the strips, what I would probably do since a lot of these samsungs, specially the NU models can have burnt diffuser sheets is carefully take it down to the backlights and check those diffusers to make sure they are ok and not burnt, I think where the most problems with panels getting broken is you have to make sure, when you put the panel back on that it sits even, smooth and exactly how it was before, slow and light handed, might have to get the backlights from aliexpress I guess if they're too high on ebay etc. Thanks, always like helping decent people like yourself.
                        • 12276
                        • U.S.
                        Yes, I saw the 6470U but not exactly 7470U, not sure if there's a difference or not, the 6470U is there on ali: https://www.aliexpress.us/item/32568...andl_shipto=US
                          • 12276
                          • U.S.
                          More: https://www.aliexpress.com/w/wholesa...tail.1000002.0
                          • Donny2derby
                            • Apr 2023
                            • 228
                            • Uk
                            Ok lads thanks for the help.
                            The tv is stored at work tonight. I’m going to pop to screwfix and buy some suction cups on Tuesday on my day off and then start work on the telly again Saturday night when I’m back at work.
                            Will let you know how I get on.
                            Thanks again.
                            • Donny2derby
                              • Apr 2023
                              • 228
                              • Uk
                              Do I need to buy just the one of those pal? You reckon that's deffo suitable?
                              I'd hate for us to fall out now because you've give me a bum steer on some parts I can't use! You have a reputation to keep!
                                • 12276
                                • U.S.
                                Lol, oh shit, did I forget the do this at your own risk clause. I'm proud of my amateur status, if I knew everything about fixing tvs I would be bored to death and quit, I like the puzzle factor of it all tho and trying to figure out what the fault might be.
                                  • 12276
                                  • U.S.
                                  I'd prolly get both strips, who wants the buyer back on your doorstep in a month bitching about a black spot.
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4463
                                    • Italy - Milan
                                    Noooo!! One hobbyist must learn a lot of tricks to keep the expense low, suction pump is not mandatory, first search YouTube there is a video on how to remove back cover in Samsung with metal rods and no screws, it's almost easy, delicate but easy. Then detach the panel distribution boards from other board so you can lift by one side very slowly to vertical position the glass matrix, better to do this on a bed because is low, you will get it and slowly place it in vertical on a cushion or soft cloth and touching a wall or vertical face. Another thing, you must open it right away because you must ensure if plastic sheet are damaged or not, it is not said..another important trick, the search will be wider and cheaper results if you get the strip codes printed on them..
                                    • Donny2derby
                                      • Apr 2023
                                      • 228
                                      • Uk
                                      Sonys, you're a gentleman! There's not many of us left
                                      • Donny2derby
                                        • Apr 2023
                                        • 228
                                        • Uk
                                        Thanks Davi. The set is stored at work so I don't have access to a bed sadly haha. Apart from that appreciate the advice. But I think I'm gonna buy the suction cups just to make things easier for me. I'm going to order the LED's later and will update the thread when they arrive off a slow boat from china and I can start the replacement.
                                        • Kjell
                                          Samsung Series 9 - BIOS issue
                                          by Kjell
                                          After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                                          Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                                          08-01-2025, 09:15 AM
                                          09-07-2024, 05:50 AM
                                        • Nairolf
                                          Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                                          by Nairolf
                                          I have a Samsung DM32D display.
                                          When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                                          Here’s what I have tried so far:
                                          1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                                          2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                                          3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                                          From these tests, I suspect the problem might be on the mainboard. Could anyone...
                                          08-24-2025, 03:47 AM
                                        • vincentedel
                                          Samsung SyncMaster 740n Phase Control Issue
                                          by vincentedel
                                          I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                                          I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                                          04-22-2025, 12:33 AM
                                        • Manucsl
                                          QE65Q800TATXXC Samsung TV Issue
                                          by Manucsl
                                          Hello.
                                          My TV is a QE65Q800TATXXC Samsung TV.
                                          Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
                                          Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
                                          Any ideas to check would be very appreciated 😊
                                          After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
                                          02-19-2025, 07:47 AM
