RCA RWOSU7047 Distorted picture
  • Nicktronic
    • Mar 2023
    • 247
    Hey, please the attached pics. This TV will turn on (Backlights on) but no picture provided. I tried disconnecting the right side LVDS cable between the tcon and buffer board (pic 1) and then the left side LVDS cable between the tcon and buffer board (pic 2). I get an image each time, but as you can see, there's a discoloration issue happening. But with both LVDS cables connected i get a black screen (BL ON though).
    Just curious if anybody has seen this before? I will provide pictures of the boards shortly, I'm just in a rush and wanted to get this posted and see what the experts think!
  • Nicktronic
    • Mar 2023
    • 247
    Re: RCA RWOSU7047 Distorted picture
    Sorry for the delay, I got the pictures uploaded.
    I also took some measurements on the T-Con:
    All GM V - 0
    VGH - 0
    VGL - 0
    VDDA - 0
    BUT! IF I DISCONNECT THE LEFT OR RIGHT RIBBON CABLE TO THE PANEL BOARD (or both at sametime), I GET THE FOLLOWING MEASUREMENTS:
    Gamma V
    14.99
    14.23
    12.27
    10.97
    10.19
    9.77
    8.21
    7.15
    5.58
    5.17
    4.40
    3.11
    1.15
    0.39
    VGH - 25.05
    VGL - -6.06
    VDDA - 15.93
    I've changed the T-Con without success. Am I to assume its the panel??
    • Biruslapio
      • Nov 2013
      • 552
      • Brasil
      I see some horizontal lines, probably panel failure since t-con replacement did nothing, inspect the panel boards for shorts and/or overheating components.
      • Nicktronic
        • Mar 2023
        • 247
        I will, but why do all the T-Con voltages go to zero when both cables are connected? How could any components on the panel boards get hot if there is no signal from the T-Con?
        • lotas
          • Jan 2016
          • 4554
          • Russia
          The protection is activated and the voltages in the T-CON DC / DC converter are turned off if there is a short or low resistance on these lines.
          • Nicktronic
            • Mar 2023
            • 247
            When I power on with only one ribbon cable connected (L or R), this IC goes to over 140F until the washed out/negative looking image appears (the ones that I shared in Post #1). Once the image comes up, it starts to cool down to around 86F. I can't find any information on the IC though.
            Does anybody know what it does and if it's normal to get crazy hot?
            • Diah
              • Feb 2013
              • 6357
              you have shorted gamma ic on T-CON
              • Nicktronic
                • Mar 2023
                • 247
                I already replaced the T-Con, no change.....
                • Diah
                  • Feb 2013
                  • 6357
                  you never wrote about replacing.... i am talking on yours first post the 2 photos you uploaded ob old or replacement t-con its shorted Gamma IC
                  • Nicktronic
                    • Mar 2023
                    • 247
                    I did at the end of Post #2, but that's ok! Moving on, so what can I do if both T-Cons have the same result? The 2nd one is new from Shop Jimmy. Is the Gamma IC possibly dead on both? Maybe the panel caused it?
                    • Diah
                      • Feb 2013
                      • 6357
                      sorry just i read at the end of post#2 ..
                      you replaced T-CON. but its far to call it new. the pictures show GAMMA fault. the IC you linked at post #6 are SPI NOR Flash Dual I/O . but its label look out as local manufactured by panel. so i dont know under which Taktfrequency this work, you may find from TV Spec picture Freq.
                      in general the SPI receive the Data direct from T-CON. so if the DATA Freq ( GAMMA ) fault it will effect it this why it become warm to hot and then cooling down after the image cleared.
                      you can check the VCC on pin 8 to know if its 3.3V or 1.8V. also you can carefully take it out and then turn on. if the image / half picture come clear or not.
                      • lotas
                        • Jan 2016
                        • 4554
                        • Russia
                        What is this SPI NOR Flash Dual I / O, this is a VCOM signal converter.
                        • Nicktronic
                          • Mar 2023
                          • 247
                          I think I agree with @lotas, after reading a little bit about VCOM, it can cause the white picture that I'm seeing. Possibly the supply voltage is too low. Does anybody have a datasheet for this IC? I haven't been able to find one.
                          • Nicktronic
                            • Mar 2023
                            • 247
                            I took the following measurements of the VCOM signal converter;
                            left side ribbon cable connected, displaying like the picture in post #1, after the high temp run up as mentioned in post #6
                            pin 1 - 244mV
                            pin 2 - 244mV
                            pin 3 - 6.69V
                            pin 4 - gnd
                            pin 5 - 6.69V
                            pin 6 - 3.5V
                            pin 7 - 3.5V
                            pin 8 - 15.84V
                            right side ribbon cable connected, displaying like the picture in post #1, after the high temp run up as mentioned in post #6
                            pin 1 - 268mV
                            pin 2 - 268mV
                            pin 3 - 6.69V
                            pin 4 - gnd
                            pin 5 - 6.69V
                            pin 6 - 3.4V
                            pin 7 - 3.4V
                            pin 8 - 15.8V
                            Both ribbon cables connected
                            0V all pins
                            I can't find any information on this IC, see picture (same as post #6)
                            • Diah
                              • Feb 2013
                              • 6357
                              the main talking are on Data Freq. i don't know what kind of LCD build in this set IPS / VA or TN !!
                              • Nicktronic
                                • Mar 2023
                                • 247
                                Most likely the panel causing my issue, but the TV got covered under warranty.
                                Thanks for the help
                                • howardc64
                                  by howardc64
                                  Problem
                                  08-04-2024, 10:36 PM
                                • Fly_Among_Stars
                                  VIZIO E70-E3 Half picture with half TCON
                                  by Fly_Among_Stars
                                  I have a VIZIO E70-E3.
                                  Symptoms: Black screen, no picture, but LED backlights are working.
                                  I probed the power board and voltages are as listed on the board.
                                  Main board appears fine, too.
                                  I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
                                  There are two separate ribbon cables feeding the LCD.
                                  If both are connected, the screen is black.
                                  If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
                                  04-24-2023, 08:20 PM
                                • mecha1166
                                  Un70nu6900 taped lvds, how to fix washed out 1/2 picture?
                                  by mecha1166
                                  I am getting these 70 inch Samsungs daily. Dead set light comes on goes off, dark screen. Tried taping the problem lvds cable pins 13 to ? pin, used about 9 mm scotch tape. Picture comes on, no distortion lines, looks good, but 1/2 of screen is washed out. Problem seems to always be the last little strip on the bottom. Has anyone found what is actually the problem? Possibly one of three diodes there? I have a pic but it is washed out on 1/2. Anyony had success in fully restoring the picture? Thanks.
                                  07-03-2024, 05:03 PM
                                • ChattFix
                                  Samsung UN55TU700DFXZA Distorted Picture
                                  by ChattFix
                                  I have a Samsung UN55TU700DFXZA with a distorted picture and I thought it was a bad panel. I had a similar board with one number off and still tried it to see what the issue could be. The picture came out clear with only missing blue hue I think. I found a replacement board for $30 but wanted to learn if this would be the main IC or possibly something else. I don't have service manual so looking to learn about these cheap sets....
                                  06-02-2024, 03:50 PM
                                • shelby5041
                                  Samsung LCD TV no picture backlight on no 12v at tcon
                                  by shelby5041
                                  hi
                                  i have a samsung lcd tv
                                  it powers on with sound and backlight but no picture
                                  all voltages from PS are good 12v 3.3v and 5v
                                  whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
                                  i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
                                  no 12v at the tcon fuse
                                  i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
                                  the odds of having 2...
                                  10-08-2021, 08:21 AM
