Manta LED4002
  • lanada
    • Oct 2013
    • 50
    • Malta
    Manta LED4002
    Someone has firmware for CV9202H-A39 (4BT2647)?
    Thanks in advance
  • TheUser
    Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
    by TheUser
    Hello to everyone ,
    This is my first post here, and i would like to share with you a small story in case you can help me.
    Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
    All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
    I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
    02-10-2024, 02:07 PM
  • gurj1979
    Ubiquiti firmware help. US-8-150W POE
    by gurj1979
    Hi guys.
    I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
    Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
    So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
    Got New chip and writes good.
    THE PROBLEM...
    It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
    Does anyone have a Good Firmware I can have?...
    07-22-2024, 05:13 PM
  • wattage
    by wattage
    Hello Badcaps Community,
    Yesterday, 04:41 PM
  • sikocan
    NP930XED Samsung Galaxy Book2 Pro Laptop PD Firmware Loop
    by sikocan
    I hope this message finds you well. I wanted to share a recent experience I had with a laptop that had a Type-C Port issue, specifically related to a PD (Power Delivery) controller problem. After replacing the damaged PD controller chip with a new one I purchased from AliExpress, the laptop now charges properly and negotiates power as expected, allowing the device to power up. I've replaced this chip twice just in case.
    However, it seems that the laptop's BIOS is detecting an older version of the PD Firmware on the newly installed chip. As a result, it attempts...
    01-11-2024, 01:47 AM
  • skynetto
    MSI Z590 MS-7D07 rev 2.1 EC Firmware
    by skynetto
    Hello there.
    I have this mainboard (MSI Z590 Gaming edge - MS-7D07 rev 2.1) with these symptoms.
    1. SIO_3VA ON
    2. ATX_5VSB ON
    3. 3VDSW ON
    4. Mainboard stucked in Deep_S5 state
    Problem:
    RSMRST Incative. (Obviosly everything dead)
    Tried just for fun to update the BIOS with its Bios flashback function (Push button and USB stick with bios in it).
    Main Bios restored succesfully.
    When updating Bios all the voltages comes on except PCH which is not needed.
    EC Controller: NCT6687D-M
    External SIO Firmware...
    03-17-2023, 10:30 AM
