problem with lg32lv4500
  • Xristakis795
    • Mar 2021
    • 162
    • Greece
    hi to all
    i have the above model of tv it has the power supply
    EAX62865601/7
    found a similar service manual with mine
    you can download it from here
    https://www.electronica-pt.com/esque...2169401-33113/
    the problem it was burnt the fuse f100 5 ampere
    it has leakage the mosfet q602
    i change it with q601 it worked normal 2 hours almost but when i turn off and try to on it lights the led of standby red at the start after it becomes white and after turn off without have picture on the tv is dark every time i i will try to open the tv the same process repeat in relatiosnhip with the standby led
    can you suggest me something ? what must i look i mean
    thanks on advance
  • psssst
    Yamaha TSX 120 Standby Problem
    by psssst
    Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
    03-01-2024, 07:25 AM
  • theone111
    by theone111
    3. Problem: TV shuts down
    07-22-2024, 10:36 AM
  • Zeonalbasta
    Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
    by Zeonalbasta
    i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
    The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
    09-13-2024, 01:17 PM
  • valvashon
    Insignia NS-LCD19-09 no standby LED; (new problem)
    by valvashon
    Having a new problem with the 19" Insignia that I modified with one of my automatic turn on circuits. That is now completely disconnected so that is not the issue. I was doing some modifications on that circuitry and managed to short something out on the underside of the power board.
    Actually found and bought the service manual (who knew it was even available?!) which brought me to the High Voltage Startup Circuit controller chip.
    Looking up that chip number- LD7575APS brought me to the attached datasheet. I have marked my voltage readings on the schematic sheet (open in new...
    08-30-2023, 10:41 AM
  • Wolf1977
    samsung ue46c8000 problem with standby
    by Wolf1977
    hi to all
    i downloaded the service manual of power supply
    and because it has burnt the ic iCE3BR1765J and the fuse 2 ampere and probably the transformer ic801s i wanted to test the rest circuit if it has not problem so i take a power supply and give 5volt dc to the points + on nr 1 of db803 and - on minus of capacitor cb856
    but when i give voltage the relay rl801s click on and off from the motherboard i suppose something missing or goings wrong
    i connect and the power supply plug on the tv 220volt and i have desolder the transformer
    can someone tell...
    08-13-2023, 12:50 PM
