hi to all
i have the above model of tv it has the power supply
EAX62865601/7
found a similar service manual with mine
you can download it from here
https://www.electronica-pt.com/esque...2169401-33113/
the problem it was burnt the fuse f100 5 ampere
it has leakage the mosfet q602
i change it with q601 it worked normal 2 hours almost but when i turn off and try to on it lights the led of standby red at the start after it becomes white and after turn off without have picture on the tv is dark every time i i will try to open the tv the same process repeat in relatiosnhip with the standby led
can you suggest me something ? what must i look i mean
thanks on advance
EAX62865601/7
thanks on advance
