Re: Samsung LN-S3251D Black Screen
One more thing I forgot - check the fuses.
Does your DMM only read 2 digits?
Look, I'm being serious here. There are a number of causes for the 'two seconds to black' problem. One is a bad CCFL. Another is a transformer with shorted turns. A third is a bad component in the sense circuitry.
Shorted turns often cause a slight change in the resistance of the secondary - anything over 3% is significant. That would be the difference between 1.51K and 1.55K.
Replacing a transformer is a PITA, but it is much easier than identifying which diode, resistor, capacitor or transistor is bad. If you would rather just buy a new inverter, or toss the whole TV, just say so.
PlainBill
Oops.....
Make that 1.5k ohms on the secondary outputs.
The 20-pin IC is a BD9882.Leave a comment:
Okay.... here are the pics.
If you need more detail, I will have to redo them as left/right since the board is fairly long.
The first five pins (ribbon conn.) from the left are showing 24V from the PS.
Starting with the first pair of pins on the far left, the secondary side of the inverter transformers are showing 1.5 ohms on all 8 pair without variance.
What is the part number of the 20 pin IC in the center of the board?
PlainBillLeave a comment:
Starting with the first pair of pins on the far left, the secondary side of the inverter transformers are showing 1.5 ohms on all 8 pair without variance.Leave a comment:
Now to be a real PITA, I'm going to point out that most of us don't have an impedance meter, we have to make do with the ohmmeter function of a DMM. (But an impedance meter would certainly be the best way to test the transformers).
most probably a faulty inverter, test the impedances across the pins of the inverters and look for one that doesnt have the same impedance as the rest of the pack (not to say you couldnt have 2 faulty inverters)Leave a comment:
There is a pin designated B/L ON/OFF on the PS board that connects the ribbon cable to the inverter board.
When the power button is pushed, the voltage reads 4.7V then the backlights flash once. The voltage reading remains unchanged.Leave a comment:
This set is a later model (Nov. '06 vs May '06) than the last one y'all helped me diagnose.
When I first got it, powered it up, the chime sounded, the backlights flashed one time, then went black screen.
Opened it up and found about half a dozen broken backlight bulbs. Replaced them with known good bulbs, which was a very tedious process, and fired it back up thinking I had it licked.
So much for that line of reasoning as it still does the same thing, except that all of the backlights now flash once.
Checked all of my voltages and they appear to be within acceptable limits.
I am leaning toward an inverter problem.
Am I on the right track and how do I confirm?
Am I on the right track and how do I confirm?Tags: None
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... -
I also had corrosion/oxidation on the... -
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by totofHello,
I have my TV model UE50KU6070 which I am trying to repair.
BN41-02528A / BN94-10800C motherboard.
If I disconnect the motherboard from the power board, the backlight works. When the motherboard is connected the backlight works but the screen remains black.
When I plug the TV into the electrical outlet, the standby LED lights up but no reaction to an attempt to start it with the remote control for about 1 minute. During this minute the TV consumes about 20W.
After one minute the consumption drops to 0W and the TV can turn on with the remote control but... -
by VcemPzdHello everyone !
My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappearedI bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
- Loading...
