Re: Hisense rsag7.820.5687 no power no standby light
Is it a switch? Check if the contacts are jumpered on it.
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
Assuming...7 Photos -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by JimBanvilleThe sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
Opened it up and discovered the power supply is making a faint clicking or ticking sound.
I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...-
by shovenoseHi all,
I have a cheap rainbow christmas light set off Amazon which has this little power supply that has a button to change modes. I had a white set with the same power supply that I returned but I can't find any other rainbow themed ones that don't use this setup.
Anyway, the problem is every time you unplug them and then plug them in it reverts back to "Combination" mode which cycles through all these annoying tacky effects instead of going back to what you had selected or at least defaulting to "Steady on" which is what I want. So I'm thinking I can just...1 Photo - Loading...
