Intermittant power on - 42" Viore plasma
  • Stevedak
    • Sep 2010
    • 5
    I have a 42" Viore Plasma (PDP42V18HA), 4 years old. When I hit the power switch, I hear the power supply clicks, the screen gets slightly brighter but it does not turn on, the LED goes green. Then it either turns off immediately or After about 4 minutes it turns off (LED out). I unplug it and try again. After a 2-3 cycles of this, and waiting the 4 minutes, it will power on and work perfectly fine. I took the back off and looked at the power supply, didn't see anything obvious. I looked at all the other visible boards, nothing obvious. I was tempted to replace the power supply but wasn't sure if a control board could create the same problem. Based on my symptoms, can anyone say if the power supply is my likely source?? Bulging caps: When caps bulge, is it significant and obvious or subtle for the trained eye??
  • PlainBill
    • Feb 2009
    • 7034
    Re: Intermittant power on - 42" Viore plasma
    It depends on your definition of 'obvious'. Some months back a gentleman was having problems with a monitor. 'The caps look perfect' according to him. After several posts that produced stranger and stranger information I suggested he attach a picture of the board in question. It wasn't a very good picture, but I quickly identified nearly a half-dozen caps with bulging tops. Replacing them solved his problem.
    While I would NEVER suggest you are as undiscerning as that gentleman, read the links in my signature and attach a picture of the power supply.
    PlainBill
    • Stevedak
      • Sep 2010
      • 5
      Pictures of power supply
      • Stevedak
        • Sep 2010
        • 5
        More power supply pics.
        • retiredcaps
          • Apr 2010
          • 9271
          Most of your pics are blurry, but from what I can tell the caps look okay. That doesn't mean anything though.
          If PlainBill asks for more photos, for best picture quality and clarity take your boards to a window on a sunny day, turn flash off, and use macro mode. Take a top down view of all your boards (front and back). Make sure the photo is legible so that we can read the PCB printing clearly. A shutter speed of 1/125 or faster will produce nice clear focused pictures. Try to get a photo that is 2000x2000 resolution or as close as possible.
          --- begin sig file ---
          --- end sig file ---
          • PlainBill
            • Feb 2009
            • 7034
            Usually I prefer one good clear picture over many blurry ones. From what I can tell, there are no obvious bulging caps. The one on the corner of the first picture in the second group looks like there might be a slight bulge.
            As retiredcaps suggested, I'd like a single picture from directly overhead with resolution of as close to 2000 x 2000 as possible. Under those conditions any bulging is very obvious.
            One problem is some manufacturers have mastered the technique of building caps that fail without visible evidence. Another problem is there are additional supplies on some of the other boards which can also cause problems.
            PlainBill
            • Stevedak
              • Sep 2010
              • 5
              These pictures should be clearer. On the back side of the board, there is a dark spot at a solder joint. The component is an amp, mounted to a heat sink. can't see the part number of the amp. THe power supply number is USP440M-42LP
              • Stevedak
                • Sep 2010
                • 5
                THe picture of the back of the board shows a dark spot at some solder joints. The soldered component isn't an amp, it is a MR5060.
                Thanks for all the help.
                • YOUNGGUNS
                  • Mar 2012
                  • 8
                  • AMERICA!
                  Hey i have the same problem with my same tv and i was cunfused because i also dont see any bulging caps.
                  • YOUNGGUNS
                    • Mar 2012
                    • 8
                    • AMERICA!
                    can anyone help me identify any blown caps please help me.
                    • Hoopers Cooper
                      • Mar 2014
                      • 8
                      I know this is an old post, but if possible, can you tell me if you were able to repair this board? If so, what was replaced or repaired. Thanks.
                      • Hoopers Cooper
                        • Mar 2014
                        • 8
                        • kgavionics
                          • Apr 2017
                          • 152
                          Hi
                          Identifying bad caps by just looking to them can be deceiving.In my experience i have found some bad capacitors with high ESR value, even though, they looked perfect, no bulge or whatsoever.So i recommend to get en ESR meter from ebay to test them out of circuit.
                          Another advice.Capacitors are not always the origin of failure in spms. Just test other components, like diode, Mosfets...
                          • PantherDave
                            by PantherDave
                            Hi all!
                            05-29-2024, 02:01 PM
                          • GLISIT
                            by GLISIT
                            01-16-2025, 02:29 PM
                            by sam_sam_sam
                            03-31-2024, 02:12 PM
                            09-06-2024, 05:59 AM
