Samsung UE55JS8000 backlight
  • unimatrix93
    • Oct 2021
    • 343
    • Magyarország
    Hello everyone!
    I'm looking for replacement parts for a UE55JS8000 LED TV.
    Does anyone know the parameters of the individual LED beads on the backlight strips so I can replace the faulty ones instead of buying a complete new strip?
    Thank you everyone!
    • 12145
    • U.S.
    Re: Samsung UE55JS8000 backlight
    Check on that page, some of them will have full description of the leds: https://www.aliexpress.com/w/wholesa...tail.1000002.0
    • lotas
      • Jan 2016
      • 4589
      • Russia
      It is necessary to completely change all the LEDs, if you replace only the burnt ones, then after a while others will burn out and again you will have to disassemble and change the rest, and the new ones will shine brighter than the rest.
        • 12145
        • U.S.
        +100, only changing out individual leds not recommended, but if you really want to, be sure to turn the backlights way down to ty to make them last as long as possible which is good advice when changing all the strips too.
          09-07-2024, 05:50 AM
        • C152Heavy
          by C152Heavy
          Summary for TL-DR readers:
          • VCC pin (18) of PFC...
          01-11-2023, 02:53 PM
        • sansanpartida
          Samsung QE82Q70RAT no backlight
          by sansanpartida
          Hi everyone!
          Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
          My issue: No backlight.
          Model: QE82Q70RAT
          Type No: QE82Q70RAT
          The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
          So hopefully, I can fix this cheaper.
          05-22-2024, 06:56 AM
        • howardc64
          Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
          by howardc64
          TV was fixed just after removing Samsung's rear snap cover.
          This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
          Maybe PSU->backlight connector didn't have a good contact?...
          07-23-2025, 12:34 AM
        • howardc64
          Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
          by howardc64
          • Prior owner tried a replacement main board. No difference.
          • Samsung 2x red blinking standby LED = panel fault
          • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
          • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
          • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
          07-19-2025, 10:54 PM
