Samsung UE55JS8000 backlight
  • unimatrix93
    • Oct 2021
    • 343
    • Magyarország
    Hello everyone!
    I'm looking for replacement parts for a UE55JS8000 LED TV.
    Does anyone know the parameters of the individual LED beads on the backlight strips so I can replace the faulty ones instead of buying a complete new strip?
    Thank you everyone!
  • nomoresonys
    • 12116
    • U.S.
    Re: Samsung UE55JS8000 backlight
    Check on that page, some of them will have full description of the leds: https://www.aliexpress.com/w/wholesa...tail.1000002.0
    • lotas
      • Jan 2016
      • 4554
      • Russia
      It is necessary to completely change all the LEDs, if you replace only the burnt ones, then after a while others will burn out and again you will have to disassemble and change the rest, and the new ones will shine brighter than the rest.
      • nomoresonys
        • 12116
        • U.S.
        +100, only changing out individual leds not recommended, but if you really want to, be sure to turn the backlights way down to ty to make them last as long as possible which is good advice when changing all the strips too.
          09-07-2024, 05:50 AM
        • C152Heavy
          Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
          by C152Heavy
          Summary for TL-DR readers:
          • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
          • Have obtained Samsung schematic & service documents - Can upload if helpful.
          • Have read ALL applicable threads
          • C1818 and CP820 replaced as low hanging fruit
          • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
          • VCC pin (18) of PFC...
          01-11-2023, 02:53 PM
        • sansanpartida
          Samsung QE82Q70RAT no backlight
          by sansanpartida
          Hi everyone!
          Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
          My issue: No backlight.
          Model: QE82Q70RAT
          Type No: QE82Q70RAT
          The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
          So hopefully, I can fix this cheaper.
          05-22-2024, 06:56 AM
        • Ierwin
          by Ierwin
          05-13-2025, 03:31 PM
        • Warrensmith
          Samsung BN44-00807E Low Backlight
          by Warrensmith
          Symptom is dim backlight - this set came in with almost no backlight.
          Samsung UN55JU6500FX2A
          1 - Replaced all backlight LED strips (set had lots of hours at level 20 backlight)
          2 - Changed out what appeared to be a bad Q9102C on BN44-00807E - not shorted or burned but appeared to be open. I was able to read (with difficulty) the part number - however I may have misread it - Can someone confirm that this is indeed an AOD9N40.
          Backlight improved significantly - about like it would be set to a level 3 or 4. Setting all the way to 20 seems to...
          10-27-2022, 07:09 AM
