HiSense 65H6510G no boot
  • bohaboha
    • Nov 2012
    • 1017
    • sweden
    #141
    Re: HiSense 65H6510G no boot
    From what I'm seeing, hisense is using the cheapest eMMC and everything else they come across, the built in apps are junk and just shorten the life of eMMC, wondering if just a universal mainboard would be an easier, maybe better solution for some, otherwise looks like you need a programmer and the ability to replace these chips without burning them up or buy them pre-programmed which may prove a tough find but still have to be very careful replacing, a little video of a guy replacing one. He looks pretty competent, but even so he had to go over it again, I can just imagine all the ways this can go wrong for the average do it yourselfer, I'm confident that you can do it but I bet a lot of folks would mess this up somehow: https://www.youtube.com/watch?v=tP3oUCX2ID0
    What kind of hot air station that men in video have?
    • lotas
      • Jan 2016
      • 4761
      • Russia
      #142
      QUICK 861DW ESD https://aliexpress.com/item/4001146200284.html
      • bohaboha
        • Nov 2012
        • 1017
        • sweden
        #143
        Thank you so much lotas. a very costly piece of equipment. another question: After he cleaned the tin and added flux to place the MMC, I don't see him applying any tin again in the video? Should you do so or maybe he didn't show it on his video?
        • lotas
          • Jan 2016
          • 4761
          • Russia
          #144
          Didn’t show or there was already a prepared eMMC with applied balls....
          • Zonalimitatore
            • Apr 2024
            • Italy
            #145
            Hello there guys. I have a different TV (Saba) with the same problem. Is another size TV (43"), but have the same chip.
            The problem start with a program TV image stuck. No way to power off,reboot, commands from remote. So unplug it. From that moment the single red blink once less 1s every 20/30 seconds, but no sign at all.
            So i've connected usb/com adapter to GND0-3V3STANDBY-RX1-TX1, connect to terminal and here the results.
            Two errors, but i can't know what is mean. Do you?
            Ty
            • lotas
              • Jan 2016
              • 4761
              • Russia
              #146
              Bootloader is damaged, eMMC is not fixed...
              • Zonalimitatore
                • Apr 2024
                • Italy
                #147
                It mean it's good to trash, or can be fixed?
                • afiftyp
                  • Jun 2024
                  I have a HiSense H65U8B with a "RSAG7.820.8776/ROH" mainboard that does no longer boot.
                  In the UART log I see the following:
                  #_eMMC_RPMB_Check_Program_Key
                  ~eMMC_RPMB_Read_data fail!
                  opteeA_fail
                  AUTH_OPTEE_FAIL
                  and the TV does not boot but tries to find a SW update on USB.
                  I have the latest image and the update goes thru successfully but it still does not start and would repeat the update in an endless loop.
                  So I thought using the MStar tool would eventually help and I was able to read out the DeviceID and sent it to email addresses given in the pdf document to obtain the corresponding update password.
                  It seems that mstarsemi.com is no longer active because after 2 days I received undelivered mail notification.
                  Does anyone have an idea if there is another address that one could use to obtain this password?
                  I would be able to replace the eMMC by a new one, but I don't know if the SW generates and stores a key for the RPMB by it own of that has to be inserted from external (and how).
                  • afiftyp
                    • Jun 2024
                    I'm still not willing to give up on this board.
                    The link1 in post https://www.badcaps.net/forum/troubl...09#post1803209 mentions a utility named mbootnize. It seems to be required to manipulate a dumped image in order to be able to flash it to a new emmc (factory process). Does anyone happen to know where to get this program?
                    • Dragunov
                      Need firmware for HISENSE 40A5NQ
                      by Dragunov
                      i need firmware for HISENSE 40A5NQ so i can flash it via USB...
                      Tried via USA website but it doesnt accept my serial number TV was bought in croatia.
                      Remote works only to power on tv and after that i cant select firmware update or anything else...
                      07-07-2025, 01:33 PM
                    • joby91
                      SONY KD-55AF9 OLED MAIN-BM3-1-983-356-11 EMMC Firmware
                      by joby91
                      I have SONY KD-55AF9. Mainboard MAIN-BM3-1-983-356-11 with defekt EMMC.
                      I wanted to buy new EMMC and Flash the firmaware on it. Does anyone have the firmware for this TV. I would be really grateful.
                      I found one chat about firmware on ************** forum but i cannot read the comments.
                      https://**************/forum/108-114100-1#880537
                      09-04-2024, 01:34 PM
                    • privato89
                      Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                      by privato89
                      I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                      Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                      Let's begin:
                      Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                      03-26-2024, 06:37 AM
                    • DoubleBogey817
                      HISENSE 65H6510G (13 AUG 2020) - POWER ISSUES
                      by DoubleBogey817
                      HISENSE 65H6510G (13 AUGUST 2020)
                      When powered on, initial splash screen (HISENSE ANDROID TV) displays for a few seconds then power shuts off. Tried updating firmware with USB flash drive (can't find 4GB drive but did format larger drive in FAT32) with no luck. Flash drive would be accessed but would never get to the update process. I have ordered a board (RSAG7.820.7911/ROH, PART# 242585) from eBay which will arrive in a few days. Does anyone have any input of whether I am chasing down the right trail or should I be trying something else? I appreciate your time and wish to say thank...
                      02-16-2024, 10:58 PM
                    • Sus256
                      HISENSE 65E7KQ PRO - no boot
                      by Sus256
                      Hi all!
                      HISENSE 65E7KQ PRO
                      RSAG7.820.13512 - chassis
                      MT9618BAATAB - cpu
                      RSAG7.820.12059 - power
                      HD650Y3U77 - panel
                      KLM8G1GETF - emmc
                      Replaced emmc.
                      Terminal log
                      UART
                      AC_ON
                      E-B
                      FDE enabled
                      06-01-2025, 02:11 AM
