Tcon fuses
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4535
    • Italy - Milan
    Tcon fuses
    How many of you have encountered often broken fuses on tcon and them was the only fault on a tv:
    1) On old heavy LCD TV: quite often - very rare?
    2) Recent LCD then mostly LED era: quite often - very rare?
    thanks..
  • ducky29
    • Dec 2015
    • 369
    • Europe
    Re: Tcon fuses
    In oldish lcd tvs it was quite common finding just the fuse faulty.
    Nowdays on these newer sets I have never ever found a broken fuse.Most of the time no picture means dead panel.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4535
      • Italy - Milan
      Re: Tcon fuses
      thanks 4 sharing
        Surface Mount Fuses Fundamentals Datasheet
        TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
        TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
        10-07-2024, 06:07 AM
      • kca
        by kca
        Hello all ~
        08-31-2025, 06:38 AM
      • x_orange90_x
        TCL 50S535 bad tcon or panel issue?
        by x_orange90_x
        Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
        03-29-2025, 11:02 PM
      • advant
        by advant
        02-03-2020, 12:25 AM
      • Hakuu
        by Hakuu
        Hi There,
        More Details
        TV Model - LG OLED77G1PUA
        07-12-2023, 02:37 PM
