Samsung QN55LS03 | The Frame TV | Weird power cycle and restart problem
  • VikramB
    • Mar 2023
    • 6
    • India
    First thread here on this forum, excuse me if I miss something in my first post.
    I have the 55” variant of the Frame TV which is essentially a QLED tv. There's a weird problem where it would keep on restarting on its own. Funny thing is it might work perfectly for couple of days and then decides to go down the restart route. A few pointers:
    1. If I let the TV sit idle for a day, for the very first time it boots after that time period it usually keeps working for 5 minutes before restarting. After that it restarts every 5 seconds.
    2. I've tried the tape method and seem to find a pin where I can see the picture (although with frame skips, vertical lines and what not) and the TV doesn't restart. It's the VGHD panel pin.
    3. Since I've tried the tape method, that also implies I've eliminated other potential causes. Basically if I remove the display connector, there's sound and no restarting.
    4. If the panel is faulty, why don't I see any dead pixels or horizontal/vertical lines when the TV is working properly?
    I do have the service manual with me but not able to decode which pins should I try masking for a stable picture. I don't mind even if I end up with a dead pixel row. Any sort of help would be appreciated.
    • 12157
    • U.S.
    Re: Samsung QN55LS03 | The Frame TV | Weird power cycle and restart problem
    Guess it depends on where the short is, here's a good video: https://www.youtube.com/watch?v=pfrRhw7-ZII
    • VikramB
      • Mar 2023
      • 6
      • India
      Thanks for the prompt response. As a matter of fact, I saw the exact same video before going ahead with the tape fix. Unfortunately this particular model doesn't have an isolated TCON board. Also, the COF strip has a connection for the right part of the screen, but the left part is soldered. I've tried disconnecting the right side and it still restarts. Can't check the left part though
      Now, coming to what's shown in the video, I've actually tried taping those CLK pins but I end up creating more mess. Instead of any improvement the image deteriorates further. The best I could do was by masking only the VGHD pin. I guess I'll have to check for shorts on the driver.
        • 12157
        • U.S.
        Good idea, some have been having various luck by removing diode packs and or resistors on the panel driver boards.
        • VikramB
          • Mar 2023
          • 6
          • India
          One thing I’m still not sure about is the varying time between restarts. A short, if it’s there somewhere, is a SHORT after all. It shouldn’t be unpredictable. For instance the TV is running fine for the last 2 hours, making me scratch my head even further.
            • 12157
            • U.S.
            Howardc64 just had good luck removing resistors on his LG: https://www.badcaps.net/forum/showthread.php?t=116761
              • 12157
              • U.S.
              Originally posted by VikramB
              One thing I'm still not sure about is the varying time between restarts. A short, if it's there somewhere, is a SHORT after all. It shouldn't be unpredictable. For instance the TV is running fine for the last 2 hours, making me scratch my head even further.
              Yes, that is a very good question, the first thing I always think when the shutdowns are random is a bad/weak capacitor or an iffy solder joint.
              • VikramB
                • Mar 2023
                • 6
                • India
                Aah right the caps. Even a weak solder joint too could be the culprit. I guess I’ll just seek some professional help. Samsung quoted me an insane amount for the panel. They don’t do repairs anymore. Instead they just change the complete part.
                • VikramB
                  • Mar 2023
                  • 6
                  • India
                  Update: Got a professional to look into the issue. A panel COF is the culprit. Will probably have to get the whole panel replaced since the part is not available here.
                    09-07-2024, 05:50 AM
                  • ChristianBr01
                    LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                    by ChristianBr01
                    I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                    The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                    What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                    04-23-2025, 01:48 AM
                    09-06-2024, 11:40 PM
                    09-06-2024, 08:40 PM
