LG M2362DP Backlight problem
  • ononos
    • Mar 2023
    • 9
    • GREECE
    hello everyone!
    As the title states i am an owner of an LG flatron M2362DP 23 inch monitor Tv. Since i currently use it as a tv i'm posting the problem on the "troubleshooting tvs and video sources" section.
    I'm from Greece so English isn't my native language, so please forgive me for any mistakes i make. I have basic knowledge in electronics, and although i have a degree, many things have changed since i finished a 2 year coarse (over 30 years ago). Occasionally i repair easy stuff, mostly things that break at home like appliances.
    So i decided to try to repair my broken TV which i use as a secondary one in the kitchen. Well the problem is that there is no backlight. The tv works, i have audio, and i can see an image on the screen if i use a flashlight on it. So the problem is the backlight. Upon opening the TV i discovered two boards, the main board and the psu - inverter board. So (correct me if i am wrong) the problem must me in the psu - inverter board, since none of the 4 ccfl lamps are working .
    I managed to find and download the service manual of the tv but there are no schematics or troubleshooting for the psu - inverter board in it. I've measured with a multimeter the components on the inverter section of the board but did not find any shorts. I have tested the inverter transformer with a multimeter and the primary coil has close to zero resistance. I assume that is normal. The part number of the board is 3PAGC20009A-R and i include photos in this post.
    I would very much appreciate it if someone could guide me through troubleshooting the board or if someone has encountered the same fault with this tv.
    Thank you in advance
  • ononos
    • Mar 2023
    • 9
    • GREECE
    Re: LG M2362DP Backlight problem
    I'm planning in forcing the ccfls to stay on just to see if anyone is faulty. In the picture of the connector I assume the "ON" means inverter on and the "DIM" controlls the inverter dimmer. Does anyone know what the "M/S" and "OLP" mean?
    • lotas
      • Jan 2016
      • 4649
      • Russia
      "OLP" - overload protection
      • ononos
        • Mar 2023
        • 9
        • GREECE
        Hi again
        This is what i have done so far:
        - replaced all the electrolytic capacitors - didn't work
        - replaced the mosfets that drive the inverter (aop605) - didn't work
        - took apart the screen and discovered a bad connection on one of the ccfls. I resolded the bad connection and the lamps work!
        But know there is a white vertical line at the right part of the screen. I have measured both ends of the flat cable that connects the main board with the screen for continuity and it seems ok.
        Also when i disconnect the flat cable the white line goes away - all i see is a black screen (the backlight stays on)
        Could i have damaged the screen when i took it apart? Is there something wrong with the main board?
        • lotas
          • Jan 2016
          • 4649
          • Russia
          You could tear, tear, or detach from the glass one of these cables, when you took it apart, put it back together.
          • ononos
            • Mar 2023
            • 9
            • GREECE
            lotas thanks for the quick reply. i have inspected the cables, the seem ok.
            Because i only took the backplate off, i'm worried ithat i may have damaged the other end of one of the plastic cables. How do they glue back on?
            Here is a picture of the white line:
              • 12206
              • U.S.
              Inspect for damaged pins etc, clean and refit the cables, in case they are dirty or misaligned a little, if no luck prolly did damage something, look and see if one of the connecting tabs is where the line is, if you can get to it you can try putting a little pressure on the tab where the line is, see if the line changes any. If tv is fully assembled can try squeezing the bezel where the line is, NOT the screen, to see if line changes any, that worked sometimes in older tvs where a little squeeze would make the contact needed to get rid of a line, just a little test for tvs with lines before dis-assembly, if a bezel squeeze or a slight flex of the bezel changes a line then it could be a tab bond getting poor contact.
              • lotas
                • Jan 2016
                • 4649
                • Russia
                Here, no cleaning and displacement of the lvds cable will not help, there is obvious damage to the cable going to the glass.
                • ononos
                  • Mar 2023
                  • 9
                  • GREECE
                  Double checked, cleaned and aligned all the connections. No change. The white line isn't aligned with any of the tabs. Put pressure on all four of them - no change. Is it worth taking the screen apart again? Is this fixable?
                  • ononos
                    • Mar 2023
                    • 9
                    • GREECE
                    No luck with the bezel squeeze. Is this thing fixable?
                    • lotas
                      • Jan 2016
                      • 4649
                      • Russia
                      The white line will not coincide with the damaged cable, since there are only 4 of them and they are distributed over the entire screen, disassemble again and view under a magnifying glass.
                      • ononos
                        • Mar 2023
                        • 9
                        • GREECE
                        In case any of them has detached, how to repair them?
                          • 12206
                          • U.S.
                          Picture isn't very clear, can't see any damage, are those screws holding the panel driver board? if so you may have tightened that one a bit too much where the line is, maybe try backing it off a little if it is.
                          • lotas
                            • Jan 2016
                            • 4649
                            • Russia
                            If you torn or peeled off the glass, then you can't restore it at home.
                            • ononos
                              • Mar 2023
                              • 9
                              • GREECE
                              Okay i,ve dismantled the screen again, inspected with a microscope and found no physical damage, no tears, no bents - nothing. I applied pressure to the tabs while the tv was on with no change. The white vertical line won't go away.
                              I'm thinking know on bying a new screen. Does anyone know if the samsung ltm23ht01 is compatible with my screen lg lm230wf1- tle1?
                              Will the samsung panel work with my tv? Have they compatible connectors?
                              • lostone
                                Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                                by lostone
                                Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                                First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                                When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                                05-19-2024, 11:40 AM
                              • Honziq
                                Backlight problem - Asus M3200WU, board Gapal LA-L291p
                                by Honziq
                                I have this All-in-one PC, after SSD change there is no picture. I was found out it is a backlight problem, but LEDs are OK. There is 4 led strings each working on 42,4V, but from board is comming only 5V.
                                I was repaired many backlights before but this design i will not understand.
                                For me it looks like it is waiting for some signal from screen to start up the backlight or something like this. Nothing seems to be damaged or shorted here.
                                Can someone explain me please what to do, what to check?
                                Thanks....
                                11-20-2024, 01:24 PM
                              • howardc64
                                by howardc64
                                Problem
                                08-04-2024, 10:36 PM
                              • jimbofz
                                lg 32LC46 backlight inverter board fault
                                by jimbofz
                                Hi this oldie had no backlight .after replacing caps on 24v rail ,
                                still no b/l this uses inverter type:1315 B1-16A,
                                im sure ive come across the same inverter in a samsung possibly le32r88bd ?
                                all t/x in board test ok ,so i fitted 15k and led to pin 4 of oz964gn ic
                                this allows protect to be temporary overridden.
                                b/l now comes on
                                but the left hand side of pic is gradually darker than the right side
                                i have the cct for the tv
                                but it does not have inverter cct.
                                i opened it up to inspect the ccfl tubes
                                and they dont have any...
                                12-19-2021, 06:58 AM
