Re: Tv Philips 47PFL3188H/12 (chassis tpn10.1e la) No led No power
tried it, it remains off, the voltage remains at 8V
You can also do a dirty test on those caps you changed, set meter on 20k ohms and see if they all do the same thing with a probe on each leg, reverse probes, they should rise or fall in a steady manner.Leave a comment:
You wouldn't think they would need to make tvs in a thousand different configurations but they just have to for some reason.Leave a comment:
ok, thinking it must be ground, then try UNHOOK cable from powerboard to mainboard, leave it off, take three 1k ohm resistors and jump 1 from ground to ps-on, 1 from ground to on/off and 1 from ground to dim, then plug in power cord and see if backlights come on and stay on.Leave a comment:
putting the 3v on ps_on I think the power supply turns on because on the 12v line I find 11.7v but the backlight does not turn on
are you sure philips is like samsung and should turn on the backlight too?Last edited by fanaticgames; 03-09-2023, 01:34 PM.Leave a comment:
maybe try tracing pin 2 back thru the mainboard and see what component it's going to.Leave a comment:
now i try, i have the 3v jig used with lg tvLeave a comment:
I suppose the easy way is to slip the wire from pin 2 off of cable on powerboard side, you just take a little flat screwdriver and lift the little tab a little and it slips out, with that wire out inject about 3 volts and see if backlights come on.Leave a comment:
with this model do you need to bridge ps on to gnd or do you need to inject a voltage greater than 2V on ps on?Leave a comment:
ok, looks like you are missing 2 on/off, that's the backlight signal that comes from the mainboard, I would check the powerboard as stand alone.Last edited by nomoresonys; 03-09-2023, 01:06 PM.Leave a comment:
is it normal that by connecting only the motherboard the voltage goes from 8 to 11.3 as if I turn it on?Last edited by fanaticgames; 03-09-2023, 01:07 PM.Leave a comment:
Test it, meter on vdc, black probe on metal chassis ground, red probe on pin 2, on/off, tv in standby, take note, leave probe where it is power on tv, take note, do the same for pin 3 ps-on. Suppose dim could have various readings depending on settings.Last edited by nomoresonys; 03-09-2023, 12:59 PM.Leave a comment:
done, no changeLeave a comment:
Same old procedure, test all diodes and resistors on powerboard and check all solder joints, is a good start.Leave a comment:
heat those other electrolytics nearby with a hairdryer for a couple minutes and try it while its still hot, no change, heat the rest of the electrolytics on the board and try it, see if there's any temporary change.Leave a comment:
I have this philips tv that doesn't turn on (no red led), it had 4 capacitors leaking on the output and I changed them but it still doesn't work, any suggestions?
the output voltages I get are:
11/12 11.3v
9/10 11.3
Ps on: 3.6v
1/2 0v
the motherboard heats up on the cpu sideLast edited by fanaticgames; 03-08-2023, 03:01 PM.Tags: None
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
This specification for the HP Pavilion Power Pavilion Power 15-cb009nl Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 15-cb009nl boardview and Pavilion Power 15-cb009nl schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...09-06-2024, 05:59 AM
by CurtisCHello everyone. I'm brand new to the group. I'm trying to fix this Philips 4K TV. I have minimal experience with most of this so forgive me if I don't understand half of what is posted on these forums. I'm trying to find my way through it.
Basically I got the TV from a previous owner who said it just died on them. So I wasn't there when it broke. It will not power on, no lights, no backlight, no sound.
The output of the power supply has a 27 pin connection to the main board. Pins 18-27 (labeled P-On+20v) are the only pins reading power at 12v each. The pins marked ALL+3.3v, which... - Loading...
