TCL 55s405 No Power, No Display
  • leggot
    • Oct 2014
    • 50
    I have TCL 55s405, originally diagnosed it with no power. The fuse and caps were fine. Measured the voltage from the powerboard and the output pins were 0volts. There are pictures of the boards in this post https://www.badcaps.net/forum/showpo...7&postcount=20 Nothing obvious on the powerboard is the issue, but that's on hold until I can verify the rest of the unit works.
    Decided to bypass the powerboard and I put 12volts directly to the mainboard and applied 216 volts to the backlight. The backlight seems to be fine and turns on as expected. The mainboard appears to be on, as there is a light for optical audio, the indicator light is on and I can hear sound from the speakers. However the display doesn't appear to power on. I located the fuse on the t-con board and it gets 12volts on both sides.
    The variable power supply is at about 12 volts and 0.5 amps. It is limited on voltage, I have not tried outputting more than about 12.2volts.
    Any suggested next steps to diagnose the issue?
  • Storyteller12
    • Jun 2020
    • 624
    Re: TCL 55s405 No Power, No Display
    Sounds like power supply board is bad. Either replace it or troubleshoot at component level.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
    • Bonaventure Vigil
      ACER ASPIRE A515-52G CAN ON BUT NO DISPLAY, NO POWER AT VCC_GT
      by Bonaventure Vigil
      Dear All,
      Please really2 need Help on this Acer A515-52G Motherboard Compal EH5AW LA-G521P Rev: 1A.
      At first this laptop can on, keyboard light on but no display. Open the motherboard, found out the PQZ3 Mosfet and PUZ3 ic near it burn. Refer picture below. Then I replaced both. All the power rail 3.3,5,1.2, 1.35, 0.8V have power back after i turn on the laptop except for the VCC_GT rail. Voltage at Power Supply showing 0.000A before turn on, after turn on it became 0.5 0.6A. Seem cannot boot and still no display. Then I replaced the PUG1 and mosfet, but the VCC_GT still no power....
      12-12-2024, 10:22 AM
      03-31-2024, 02:12 PM
