Hisense 65a7300ftuk - RSAG7.820.9659 schematics?
  • retrorepair2
    • Feb 2023
    • 75
    • United Kingdom
    I'm struggling with the above 65" TV, to be honest I'm not super familiar with TV repairs in general but the power board does seem to be giving me 12v and 19v (actually fluctuates between 18-20v).
    Symptom is red standyby LED comes on, pressing power it will blink once, the second blink is brief where protect kicks in and goes back to steady red standby light.
    The backlight did very briefly flash on a couple of attempts while probing voltages, I definitely wasn't shorting anything and it doesn't seem like slightly flexing the mainboard makes any difference.
    I've also not got any voltage at all on the LED output on either left string or right string (assume that's what LP, LN and RP, RN means on XP6). Surely there should be something there when it's trying to power on?
    Attached are images of the boards but feel like without schematics I'm going to have a hard time diagnosing this.
    Is there any way I can test the LED strings? L and R both measure 5.7ohm across P and N with the leds connected, about 43k without.
  • retrorepair2
    • Feb 2023
    • 75
    • United Kingdom
    Re: Hisense 65a7300ftuk - RSAG7.820.9659 schematics?
    I did notice L28 which seems to feed the IC above it (CS602) is 7.5v across the inductor when it's trying to boot, is this normal?
    • retrorepair2
      • Feb 2023
      • 75
      • United Kingdom
      Well I was completely wrong, I was testing the speaker output. Idiot.
      The LED output is on the PSU and when the standby button is pressed, jumps to 230v then stays steady until the rest of the system goes back into standby.
      This seems to suggest from what I've seen, the LEDs may not in fact be the issue then? Is the a signal to turn the backlight on via the data cables to the display? It's really odd that it'll once in like 50 trys flicker the backlight a bit too.
      • retrorepair2
        • Feb 2023
        • 75
        • United Kingdom
        Last note, I found the screen is coming on shining a light on it. I see the Hisense logo for about a second until it goes back to standby. Guess that's looking more like a bad LED then?
        The LED connector coming from the panel looks completely open, should there be a resistance on there? Is there a way to test these LEDs without taking the whole thing apart?
        • tech9pc
          • Sep 2021
          • 49
          Don't overthink it. If you did the flashlight test and can see an image. It is bad led(s). I have fixed about 6 of these recently from 58" to 65" sharp / hisense. They are sold with backlights blaring at 100% and average user does not know that you can reduce them to extend the LED life. I set them to around 60 and picture is still bright. Been using one in bedroom for over a year now no problems. Here is a link to Aliexpress.com. Same leds you'll pay 100 bucks for in north america which orders them all from overseas cause we don't make them ourselves. only 27.00 shipped by PMALL. I have ordered from them several times. https://www.aliexpress.com/item/1005...d=SrpxOT6bbwD1
          Good luck and happy fixin! Get R Done! lol
          • retrorepair2
            • Feb 2023
            • 75
            • United Kingdom
            Thanks, yeah assumed as much.
            It's someone else's problem now anyway, I didn't have the space to do it properly.
            • tech9pc
              • Sep 2021
              • 49
              Ya sorry to hear that. I am in little cottage not much room either. Somehow manage with my little kitchen / living room island lol
              • hispeck
                Hisense tv model H43B7100 red light blink
                by hispeck
                This hisense tv came with red light blink . What I did was to give the board a separate 12v and it came . Now I know the fault is from the power section. Can someone give a guide how to fix this please . The mainboard no RSAG7.820.8752/ROH...
                03-25-2023, 08:06 AM
              • cloo
                Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                by cloo
                I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                After doing a factory reset this problem was gone and the picture was back to...
                01-06-2025, 06:02 AM
              • EazyBone
                Un50cu7000 2 blink oddity *partially solved
                by EazyBone
                I write this to maybe help another with this TV.
                So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
                The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
                03-18-2024, 10:24 PM
              • Coolgoodman
                Faulty Hisense 85Q6NAU TV
                by Coolgoodman
                85” Hisense TV
                Greetings,
                Request for Technical Assessment – Faulty Hisense 85Q6NAU TV
                Dear TV technicians of forum, I hope this message finds you well.
                I am writing to seek assistance regarding my 85-inch Hisense Smart TV, model 85Q6NAU, which is currently experiencing a fault. The unit is approximately two years old, and I am not sure if it has a warranty.
                I have attached a photo showing the issue for your reference. I would appreciate it if your experienced technician could kindly review the image and provide some insight...
                07-24-2025, 03:02 AM
              • Vebririon
                panasonic TX-P50V10E 6 blink led problem
                by Vebririon
                I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
                Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
                I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
                05-17-2025, 10:16 AM
