Samsung "MU" series (UN, UA, UExxMUxxxx) fault dump IC1604 25Q40...
  • yureyko
    replied
    Originally posted by lotas
    There should be only (S3, S7, S9, S14).
    Try to record your native dump again via NeoProgrammer_2.2.0.10.
    In the program:
    1. Click "Detect Chip" and select W25Q40CL and "Select IC".
    2. Click "Unprotect".
    3. Click "Clear IC" and "Yes".
    4. Click "Open File" and select your corrected dump.
    5. Press "Program IC" and "Yes".
    6. Click "Verify IC".
    7. Press the down arrow to the right of "Unprotect" and select "SREG Edit", put a check mark on SRP0, BP1, CMP, QE (S3, S7, S9, S14) and press "Write" and "Yes"
    7. Close the program. Ready.
    Dear lotas ,​
    I already have some default parameter set. That's why I can't set the register code 0x42.
  • lotas
    replied
    In the program:
    7. Close the program. Ready.​
  • yureyko
    replied
    Then check what status register is set, maybe it has crashed (it should be 0x88, 0x42).
    Dear lotas ,
    After installation in the TV, the status changed to 0x46.
  • yureyko
    replied
  • lotas
    replied
    Originally posted by yureyko
    Interesting...
    All voltages are present, but the indicator does not light up.
    However, when I try to flash the SPI with a working firmware from a similar model, the indicator lights up, but there is no startup...​
  • yureyko
    replied
    Your dump is working, the problem is different...
    Interesting...
    replied
    The thread title has been renamed to Samsung "MU" series (UN, UA, UExxMUxxxx) fault dump IC1604 25Q40...
  • lotas
    replied
    Greetings friends,
    i have a Samsung TV UE40MU6402U with board BN41-02568b
    The problem is that i have no standby
    I thint that maybe the problem is software related since i have voltages in board.
    I read the IC1604 (W25Q40CL)
    Propably problem is the IC1604 but i read all of them.
    If someone knows or have software to help please you are welcome.
    Thanks in advance for your time and your help.​
  • yureyko
    replied
    Greetings friends,
  • lotas
    replied
    Originally posted by ducky29
    Thanks Iotas. It works fine!
    Ok!
  • ducky29
    replied
    Hi, try the working dump.
  • lotas
    replied
    Hello Iotas. Can you please check this dump? UE43NU7022K. Thank you!
  • ducky29
    replied
  • lotas
    replied
    Originally posted by David Rocha
    Hello! My TV is a Samsung UN43MU6100G from board BN94-12431J, CODE: BN41-02568B.Dump from this! Could you help me a fix this problem? This TV in standby stay blinking and not turn on!
    Your dump is fine, it works, the problem is different.
  • David Rocha
    replied
  • DJJaro
    replied
    Hello. I have broken IC1604 from board BN94-12432B.Dump from this threed not working. Is possible fix? Thank you.
    Edit: solved, must be changed status register. Board working OK, thank you.
  • srdi
    replied
    Телевізор не включається, немає режиму очікування! SAMSUNG UE55MU6172
    The TV does not turn on, there is no standby mode!​ SAMSUNG UE55MU6172
  • lotas
    replied
    Originally posted by Beard dwarf
    Big thanks for help, everything works. Happy New Year!
    Ok! Happy New Year!
  • Beard dwarf
    replied
    Try these dumps for t-con (25q80).
  • lotas
    replied
    09-07-2024, 05:50 AM
  • totof
    Samsung UE55MU6102K IC1604 dump needed - TV don't start
    by totof
    Could you help me...
    I have a Samsung UE55MU6102K with the following problem : I disconnect the motherboard from main power supply from and the backlight leds light up.
    Then motherboard connected, standby led is on and current consuption is 18W.
    Then trying to start the TV, the standby led is blinking once but TV don't start and standby led stay red.
    Maybe the firmware in the IC SPI Flash W25Q40CL (IC1604) is corrupted.
    The model of my TV is :
    Power supply BN44-00807A
    Main Board BN41-02568B / BN94-12765W
    Panel CY-GM055HGLV3H...
    05-01-2023, 04:30 AM
  • Habble7
    by Habble7
    Suspected Cause:
    Troubleshooting Attempts:
    05-22-2025, 07:28 AM
  • jeangonbay
    Samsung UE43MU6105K IC1604 dump needed - TV don't start
    by jeangonbay
    Could you help me,I have a Samsung UE43MU6105K with the following problem, dead TV, when I disconnect the main power supply to logic board, the leds light up.
    The model of my TV is UE43MU6105K
    Main Board: BN41-02568B
    BN94-12007Y
    Could you help me to repair the dump please. Thank you.
    02-16-2024, 05:46 AM
    09-06-2024, 11:40 PM
