Samsung "MU" series (UN, UA, UExxMUxxxx) fault dump IC1604 25Q40...
  • lotas
    replied
    Originally posted by Me_you_them
    Hi lotas,
    can you help me with this firmware???
    Samsung UE55MU6400U
    M/B BN41-02568B (BM94-12401R)
    Hi, I can, try it.
  • Me_you_them
    replied
    Hi lotas,
    Samsung UE55MU6400U
  • lotas
    replied
    What initially happened to the TV? In service mode, at the point you clicked on “Micom Update” and after that the TV stopped turning on?
    If yes, then the firmware has been erased in micom, you need to program it.
    And also, you have some strange dump 24C512, or it is so badly damaged or poorly read, try this one.
  • Ashry
    replied
    Originally posted by lotas
    Where did you get the idea that the problem is in these firmwares, if there is no standby mode and the LED is not on, then a common problem in this chassis is IC204 (stabilizer from 5v to 3.3v) and micom Weltrend, check the resistance at 1.2 pin IC203 relative ground and is there 3.3v power on these pins
    Thanks for your your support. i found that sub eeprom (24c02) is connected to this ic1203 so i thought this may be the problem.
    I measured the regulator and i/p 5.3 v & o/p 3.3 v so it is good, also the voltage at pin 1&2 3.3v and no short with ground. i tried to press the reset button but nothing happened
    how can i check ic1203 (61P805) is healthy ??
    does it need programing? if yes can it be done by CH341?
  • lotas
    replied
    Where did you get the idea that the problem is in these firmwares, if there is no standby mode and the LED is not on, then a common problem in this chassis is IC204 (stabilizer from 5v to 3.3v) and micom Weltrend, check the resistance at 1.2 pin IC203 relative ground and is there 3.3v power on these pins​
  • Ashry
    replied
    Dear Sir can you help me with dead main board ( BN41-01587) for Samsung ua40d6400un and power board (BN44-0427A)
    i uploaded the flash files from 24c02 (IC 1205) & 24c512 (IC 1401) ​
    A5 & 3.3 vdc are exist.
    thanks in advance.
  • Ashry
    replied
    Hello
    Please I need your help with this mb bn41-01587e
    5vdc exist but standby led not light and no action with power button
    IC 1401 should be reprogrammed or what?
  • lotas
    replied
    Originally posted by juani981
    Hi Lotas, my TV model is UN50MU6100GCZB, Board Code: BN41-02568B from Argentina. I'm having the same issue as another user before. The standby LED turns on for 1 sec every 15 sec. When Flashing an incorrect bin, the board stays completely dead. So I guess it could be bios related. could you help me? Thanks in advance
    Strange damage to the dump, usually if in this series the MU dump is damaged at the beginning of the dump, then the TV's standby LED does not light up at all. Try this one, I adjusted it a little, and don’t forget about the status register after recording the dump.
  • juani981
    replied
  • murtagh
    replied
    Thank you Lotas, much appricated.
  • lotas
    replied
    Originally posted by murtagh
    Hi Lotas UE55MU6172 IC401 can you fix please.
    Regards,
    Pat.
    I can, but it (dump) is working for you, your problem is not in it.
  • murtagh
    replied
    Regards,
    Pat.
  • srdi
    replied
    Try.
    Thank you very much!! Everything is working!
  • lotas
    replied
    Originally posted by srdi
    The TV does not turn on, there is no standby mode! SAMSUNG UE55mu6192 ver01
    Try.
  • srdi
    replied
  • smfvep
    replied
    Hi Lotas,
    I tried with the fix file but the TV set is dead. The standby LED turns on for 1 sec every 15 sec. The standby voltage from 8v goes to 13v. At first, the TV was totally dead. Now it looks like there is some life in it but there must be a hardware problem in the mainboard.
    Anyway, I want to thank you for your effort and time. I wish you the best. Thank you.
  • lotas
    replied
    Originally posted by smfvep
    Hi Lotas, can you fix the file, please?
    I tried some other files, but I managed only to have the stand-by led on.
    Thank you
    Try.
  • smfvep
    replied
    Thank you
  • henex00
    replied
    Thank you, I will let you know about the results.​
  • lotas
    replied
    Originally posted by henex00
    Hello, TV Saamsung UE50MU6102K, BN94-12432B, BN41-02568B damaged W25Q40CL insert, please repair.​
    Ready. Try...
    09-07-2024, 05:50 AM
  • totof
    Samsung UE55MU6102K IC1604 dump needed - TV don't start
    by totof
    Could you help me...
    I have a Samsung UE55MU6102K with the following problem : I disconnect the motherboard from main power supply from and the backlight leds light up.
    Then motherboard connected, standby led is on and current consuption is 18W.
    Then trying to start the TV, the standby led is blinking once but TV don't start and standby led stay red.
    Maybe the firmware in the IC SPI Flash W25Q40CL (IC1604) is corrupted.
    The model of my TV is :
    Power supply BN44-00807A
    Main Board BN41-02568B / BN94-12765W
    Panel CY-GM055HGLV3H...
    05-01-2023, 04:30 AM
  • Habble7
    by Habble7
    Suspected Cause:
    Troubleshooting Attempts:
    05-22-2025, 07:28 AM
  • jeangonbay
    Samsung UE43MU6105K IC1604 dump needed - TV don't start
    by jeangonbay
    Could you help me,I have a Samsung UE43MU6105K with the following problem, dead TV, when I disconnect the main power supply to logic board, the leds light up.
    The model of my TV is UE43MU6105K
    Main Board: BN41-02568B
    BN94-12007Y
    Could you help me to repair the dump please. Thank you.
    02-16-2024, 05:46 AM
    09-06-2024, 11:40 PM
