Samsung "MU" series (UN, UA, UExxMUxxxx) fault dump IC1604 25Q40...
Hello. I also have a samsung ue65mu6172 with the bn41-02568b motherboard that doesn't turn on and doesn't have the standby LED. From what I saw in the hex of the W25Q40CL chip, it seems to be corrupted at first. Can you help me with its repair? Thank you very much!Attached FilesLeave a comment:
Hi, I have a Samsung TV model UN43MU6100GCZB (mainboard BN41-02568B BN41-02568). It first had random HDMI issues, then progressed to turning on with backlight but shutting off after a few seconds. All main power rails are present. Could you please check this dump? I suspect its the main problem. Thanks a lot!Leave a comment:
Hi, I have a Samsung TV model UN43MU6100GCZB (mainboard BN41-02568B BN41-02568). It first had random HDMI issues, then progressed to turning on with backlight but shutting off after a few seconds. All main power rails are present. Could you please check this dump? I suspect its the main problem. Thanks a lot!Attached FilesLeave a comment:
My dear lotas,
I ordered the Winbond W25Q40BVSNIG and W25Q40CLNIG chips to check if there will be any difference.Leave a comment:
[QUOTE=lotas;n3596169]
Don't make me laugh, where did spi flash get the I²C Protocol from, it's not eeprom.
https://www.fs-pcba.com/ru/spi-vs-i2c/[/QUOTE
then start to laugh lotas, script written as befehl which SoC do it as I2C act via eMMC / NAND firmware , when position of script address at SPI or eEPROM different the SoC will take order but it cant deliver it to Main Firmware.. this called Step BY Step start..Leave a comment:
https://www.fs-pcba.com/ru/spi-vs-i2c/Last edited by lotas; 03-18-2025, 03:17 PM.Leave a comment:
W25Q40BVSNIG have difrent clock signal at I2C will not take effect as the CLLeave a comment:
I desolder the SPI chip and clamp it with a clip. I haven't had issues with this before.
Will the Winbond W25Q40BVSNIG chip work?
Do you use it through a clamp or do you unsolder the flash and use an adapter on the programmer?
Try another flash...Leave a comment:
I was experimenting with everything back then... Now all the settings are correct.
Try this dump.
And is your CH341A black or green?Attached FilesLast edited by lotas; 03-18-2025, 11:04 AM.Leave a comment:
Try to remove protection first, i.e. remove all checkboxes and press "Write", then erase and write dump again, then set the status register again...Leave a comment:
Maybe I have a problem with the SPI chip or the CH314A programmer. Mine is not modified. Do I necessarily need to modify it?Leave a comment:
by totofCould you help me...
I have a Samsung UE55MU6102K with the following problem : I disconnect the motherboard from main power supply from and the backlight leds light up.
Then motherboard connected, standby led is on and current consuption is 18W.
Then trying to start the TV, the standby led is blinking once but TV don't start and standby led stay red.
Maybe the firmware in the IC SPI Flash W25Q40CL (IC1604) is corrupted.
The model of my TV is :
Power supply BN44-00807A
Main Board BN41-02568B / BN94-12765W
Panel CY-GM055HGLV3H... -
by AhariHi all,
I...-
by jeangonbayCould you help me,I have a Samsung UE43MU6105K with the following problem, dead TV, when I disconnect the main power supply to logic board, the leds light up.
The model of my TV is UE43MU6105K
Main Board: BN41-02568B
BN94-12007Y
Could you help me to repair the dump please. Thank you.
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
by MephysisHello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"? - Loading...
