Replacing incandescent bulb on Pioneer LD player with led. Need help :)
  • JimBanville
    • Aug 2020
    • 118
    I have a pioneer dvl-909 LD/dvd player from 1998. It has a light on the front panel that lights up when you play a dvd. I removed the bulb and it appears to be a tiny incandescent bulb. Its measures "open"/dead and the bulb is black like it's blown. The socket it fits into measures 5v. I've looked up the schematics and there's no indication of the amperage. I don't want to spend any money on new parts, but I have a pack of like 100, 3v, 20ma LEDs and I have various resistors.
    Is there a way for me to determine the amperage going to the old dead bulb with my multimeter?
    I don't mind blowing a few of these LEDs, but I don't want to damage the player's circuitry. What LED, resistor combination should I use?
    Thanks!
  • JimBanville
    • Aug 2020
    • 118
    Re: Replacing incandescent bulb on Pioneer LD player with led. Need help
    The schematic seems to show the bulb with a diode (led) icon, but it looks like an incandescent bulb...
    • redwire
      • 3912
      Lamp VEL1022, the same style is used in car dashboards called T3 or T4.2 or T4.7 depending on OD. So it has a base and might be a 5V grain of wheat lamp like used in model trains.
      I'd replace it with a white 3mm or T-1 size LED plus 100Ω series dropping resistor if you cut a PCB trace. Or scavenge an LED out of some junk. You can remove the bulb from the base if you want to fit it in that. I'd just solder it to the board.
      • JimBanville
        • Aug 2020
        • 118
        Excellent! Thank you.
        • CapLeaker
          Leaking Member
          • 8313
          When I do LED conversions I use a LED driver something like an AL5809 etc. It keeps the guesswork or calculating the proper resistance for the dropper resistor out of mind plus you can use much higher voltage rails too. Makes it very convenient and efficient. Whatever anyone prefers, I guess…
          • Xabi
            Pioneer PD-F1007 CD player not reading
            by Xabi
            Hi guys, I need some help with a CD player. It is a pioneer PD-F1007
            The issue is that it doesn't play any disks. The disk gets loaded, spins up, but it doesn't actually plays. Just keeps spinning until I stop it.
            If I put in the CD the wrong way, it will eject it quite quickly, so the unit at least understands that a CD is in and if it's in the correct orientation, tries to read it, but for some reason it can't.
            I started with cleaning the lens to be sure, but ofc that didn't help. Also the laser is ligthing up at least, so it's not totally...
            06-19-2023, 03:15 PM
          • repair-it
            TOSHIBA DLP 52HM95 How to reset timer module on bulb
            by repair-it
            I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
            Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
            10-11-2023, 07:18 PM
            MEDION AKOYA S15447 + ext. DVD Player Notebook Specification for Upgrade or Repair
            This specification for the MEDION AKOYA S15447 + ext. DVD Player Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S15447 + ext. DVD Player boardview and S15447 + ext. DVD Player schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
            09-06-2024, 05:30 PM
          • Dobsuk
            CD Player Pioneer PD-Z560T does not open trays
            by Dobsuk
            Hi, i have got one Pioneer PD-Z560T 2 CDs player. The problem is that it is open tray 2 but close it immdetiatelly and does not open tray 1 at all. At the same time it does not play the CD which i managed to insert into tray 2. Just uploaded some short videot here as it is not very easy to explain that is happening. I can hear some noice as something is trying to spin the disc or something but do not have any idea when it is coming from.
            Any advises, please? Thanks.
            08-21-2022, 09:41 AM
          • tietoharrastelija
            Pioneer VSX-527-K distorted audio after replacing parts
            by tietoharrastelija
            my friend asked to look at the amplifier. Amp model is Pioneer VSX-527-K.
            First symptom was no power or standby.
            Found few faulty components from AMP5 Assy: transistors Q404 (2SD2390), Q410 (2SB1560), resistors R430 (0R47), R431 (0R47) and R439 (100 ohm). All belongs to Front Left Channel.
            Purchased transistors from eBay (from France). Soldered new components and reapplied thermal paste to heatsink. After it amplifier starts and can hear music ok from right speaker but left speaker has distorted and lower sound than right..
            Checked...
            02-01-2023, 11:31 AM
