Samsung UN58TU7000F no picture
  • Yanleb
    • May 2017
    • 102
    I have a Samsung UN58TU7000FXZC (same as UN58TU7000FXZA, just the Canadian model) with no picture. Backlight is on and sound is coming out just fine. Just no picture.
    What is frustrating is that there's no voltage test point and no component labelling of any kind.
    What I have found so far:
    1. No voltage at pins 91-94 of the 96 pins connector CN1300 (marked 1 on the picture). This TV set has no T-CON board. The 96 pin flex cable goes directly to the right (when facing TV) lower panel board. Itself is linked with another flex to the other side.
    2. Voltage doesn't come back if I disconnect the 96 pin flex cable.
    3. A DC to DC converter chip (VPMS2GMB, marked 2 on the picture) controls many coils. It may be the one that is marked IC400_UT (just below coil marked 6).
    4. Coils marked 3, 4 and 5 have control and produce a voltage.
    5. Coil marked 6 seems to be for internal usage. Both sides are connected to the chip.
    6. Coil 7 doesn't receive any pulse (connected directly to the chip).
    7. Coil 8 doesn't receive any pulse from the chip through the mosfet marked 9 (N-Channel mosfet marked PY8N10GR).
    8. Its output once rectified by diode marked 10 is the one that goes directly to the 4 pins marked 1 of the 96 pin connector.
    9. When I say that the twp coils receive no pulse, I mean no pulse at all. Nothing at all on my scope in single trigger mode.
    Do you have any info on the VPMS2GMB chip? Is that a clone of another chip? I'm most interrested to know if there's enable pins. That chip is hard to find. The only place I found it is through an authorized Samsung parts reseller:
    https://samsungpartsusa.com/products/1203-009371
    It is Samsung part #1203-009371. At $35.95, I have to be sure that the chip is faulty before making a call.
    According to another website, this chip is also used in the following models:
    QN50Q60TAFXZA
    QN55Q60TAFXZA
    QN75Q60TAFXZA
    UN43TU7000FXZA
    UN58TU7000FXZA
    UN65TU7000FXZA
    UN70TU7000FXZA
    UN75TU7000FXZA
    UN75TU700DFXZA
    Finally, do you know the voltage I should see at the 4 pins of the connector? It should be high since it is filtered by two sets of two capacitors in series (just at the upper-left of number 1). And what about voltage that should be produced at the output of the coil marked 7?
    Thanks.
  • lotas
    • Jan 2016
    • 4668
    • Russia
    Re: Samsung UN58TU7000F no picture
    In this "TU" series, the problem has always been in the panel itself, this chip (replacement) will not help you.
    • Yanleb
      • May 2017
      • 102
      I would agree, but why is the voltage missing even with the flex cable disconnected?
      • Cornito
        • Jan 2024
        • 93
        • France
        Hello Yanleb,
        It seems I face to the same issue with my 58TU6905 samsung TV.
        No voltage on the coil 8.
        Did you found you what was wrong and where we need to investigate?
        Regards
        • Muensteraner
          • Oct 2023
          • 5
          • Moldova
          Thanks.
          The voltage on the 4 pins connector should be 17V. And the coil marked 7 is GND, there is no voltage. Right to this coil there are two diodes, between them is VGL, that should be -10,5V.
          Did you repair this board? Now I have the same situation, but a little other board. Also three coils with voltages 3,3V; 1,9V, 1,8V and nothnig more. Even if the glass is faulty, the board should produce all the T-Con voltages after coonecting the two big pins on top right corner of the board.
          Regards
          • Muensteraner
            • Oct 2023
            • 5
            • Moldova
            Attached is a similar working board with the same DC-DC chip and it's voltages.
            • Gamerglass
              • Aug 2025
              Hey there, thanks for sharing such high quality images of this board.
              My dad has the same one, and one of the component’s got toasted.
              I’ve attached a photo of your board with the part circled, and of my part that is no good.
              I know this thread is quite old now, but do you happen to know the part number from the picture?
              I believe it is an IC3201 (part #TPS563201), not entirely sure whether the suffix would be DDCT or DDCR.
              You can see from my picture “32” but the rest is burnt off.
              Thanks in advance for any info you could provide.
                09-07-2024, 05:50 AM
              • TR103
                by TR103
                - it keeps rebooting
                01-22-2025, 04:12 PM
              • JJAAMM
                by JJAAMM
                Problem
                07-06-2023, 06:01 AM
              • Mgiffune
                by Mgiffune
                06-09-2024, 10:28 AM
              • Dodgethis
                Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                by Dodgethis
                Hello all,
                This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                09-11-2024, 07:39 AM
