Samsung UE40J5100AK Bad Picture
  • Bloopeta
    • Jun 2018
    • 526
    • United Kingdom
    Have a Samsung UE40J5100AK, and the picture is bad on one side of the screen. I have tried to photograph it best I can, the colour seems off and darker than should be, and not as sharp?
    Just wondered if this is more likely a Tcon fault or a panel fault? Or if anyone can shed some light on what may be the problem?
  • lotas
    • Jan 2016
    • 4621
    • Russia
    Re: Samsung UE40J5100AK Bad Picture
    Most likely LEDs (when degraded, they began to shine in blue)
    • Bloopeta
      • Jun 2018
      • 526
      • United Kingdom
      Its not an LED fault unfortunately, its hard to show on pic, but the picture isnt right at all, writing for instance isnt sharp and crisp as it should be.
      I change alot of backlights on LGs and Samsungs that have turned blue, so know what that looks like
        • 12206
        • U.S.
        could it be a tcon issue?
        • neilc6
          • Nov 2015
          • 1550
          Orangey image is bad panel. Connect one side of tcon at a time to see if one side is good. If it has side tabs, rip them off the bad side.
            • 12206
            • U.S.
            side tabs only in bigger panels.
            • Bloopeta
              • Jun 2018
              • 526
              • United Kingdom
              Not sure m8, either tcon or panel I would think
                • 12206
                • U.S.
                what happens if you do test in post #5?
                • Bloopeta
                  • Jun 2018
                  • 526
                  • United Kingdom
                  Please see attached pics.
                  I would say on the one where can see picture, it still doesnt look right, and has red tinge
                    • 12206
                    • U.S.
                    maybe try the tape cut-off method, could also check the caps on the panel driver boards for shorts or very low ohms.
                    • howardc64
                      Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                      by howardc64
                      • Prior owner tried a replacement main board. No difference.
                      • Samsung 2x red blinking standby LED = panel fault
                      • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                      • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                      • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                      07-19-2025, 10:54 PM
                      09-07-2024, 05:50 AM
                    • TR103
                      by TR103
                      - it keeps rebooting
                      01-22-2025, 04:12 PM
                    • JJAAMM
                      by JJAAMM
                      Problem
                      07-06-2023, 06:01 AM
                    • Mgiffune
                      by Mgiffune
                      06-09-2024, 10:28 AM
