Samsung ue58tu7100
  • thuss
    • Jul 2012
    • 321
    Samsung ue58tu7100
    My mates samsung tv. Symptoms are backlights flash then switch off.
    Some times it displays an image which fades. Suspect a bad panel.
    Disconnected main board from psu and the backlights stayed on.
    Reconnected everything. Then Disconnected the ribbon from main board to panel -backlights stayed on with sound but no image.
    I suspect it's the panel and maybe the following chip on the panel. AAT7212 which I've attached a photo of (not very clear).
    I've searched for a AAT7212 datasheet but couldn't find one.
    In the attached photo leg 3 and leg 8 are reading short highlighted by red lines.
    But Im possibly wrong just wondering if anyone has come across this and I would be grateful for any help/advice.
  • alfatv
    • Sep 2020
    • 353
    Re: Samsung ue58tu7100
    Leave that chip alone.
    Search this forum for un58tu* and un50tu*, panel issue.
      • 12218
      • U.S.
      start with an easy test, test the little mlc caps on the long thin panel driver boards, check them for shorts or very low ohms.
      • thuss
        • Jul 2012
        • 321
        Happy New to all.
        Checked all those little caps no apparent short or low ohms.
        individually disconneced the two ribbons that attach to the screen . Get pixalation on the screen when one ribbon/tab is removed but when both are attached tv just keeps trying to boot up but no image.
        On the main board side the large ribbon(lower side of main board) I've tried putting a little tape between 7 and 12- which results in a the tv staying on with sound but no image but a lot of horizontal lines.
        Maybe it's just to far gone?
        • thuss
          • Jul 2012
          • 321
          I've just double checked the panel boards and found two caps which I have highlighted that are charging up with a multimeter. the ones I have come across never do that.
          I've tried masking pin 12 to 20 no luck . Then masking pin 13 the screen displayed lines in both directions.
            • 12218
            • U.S.
            so the other caps nearby are not doing the same?
              • 12218
              • U.S.
              so what do you have with just one ribbon cable attached, is the red light lit on the optical out port of the mainboard? careful not to let the pins of the disconnected ribbon cable touch the metal chassis or anything.
              • thuss
                • Jul 2012
                • 321
                Hi In regards to your first reply only those two caps but I don't regard them as faulty.
                Yes the optical port is on.
                  • 12218
                  • U.S.
                  just set meter to ohms, if its not auto-ranging meter you may need to play with the range 2000k, 200k, 20k, 2000, etc, what is the ohm reading on those two caps and the others there in that area that are the same physical size?
                  • thuss
                    • Jul 2012
                    • 321
                    It's a autoranging meter. The caps are reading similar to the others, initially i think I wasnt being careful with the meter probes.
                    • thuss
                      • Jul 2012
                      • 321
                      Yes it's a autoranging meter. The caps are reading similar to others. I think initially I wasnt being careful with the probes.
                        • 12218
                        • U.S.
                        ok, they seem alright, now my memory isn't the greatest but I thought I saw someone on youtube doing the tape-cutoff method on a tv with no stand alone tcon and only one ribbon cable like yours has there, maybe try that, see if you can get a good image. I like this guys method he's using here, yes I realize that the one he's working on has 2 cables: https://www.youtube.com/watch?v=pfrRhw7-ZII
                        • thuss
                          • Jul 2012
                          • 321
                          Yes I saw that video -will try it again. Thanks for your help
                          • peterkos2
                            • Nov 2020
                            • 43
                            • Slovensko
                            Hello. I also have this problem, did you solve it? Thank you
                            • howardc64
                              Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                              by howardc64
                              • Prior owner tried a replacement main board. No difference.
                              • Samsung 2x red blinking standby LED = panel fault
                              • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                              • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                              • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                              07-19-2025, 10:54 PM
                              09-07-2024, 05:50 AM
                            • triplefour
                              SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
                              by triplefour
                              TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
                              tcon is built into mainboard.
                              Only one cable goes to panel boards.
                              there is a cable from one panel board to the other that links them.
                              cost cutting measure that results in us having harder time to diagnose.
                              removing the link to the second panel board allows TV to stay on with stable backlight but no image.
                              used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
                              07-28-2022, 07:59 PM
                            • NWArkGuy
                              Samsung UN65TU8000 - Panel Issue [ hole in ribbon cable ]
                              by NWArkGuy
                              Well, I will be the first to admit that I screwed up...
                              In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
                              I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
                              I have 2 that I have found and have in my possession. ...
                              10-12-2023, 10:13 PM
                            • max789
                              Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
                              by max789
                              Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
                              I made the following tests:
                              1. Disconnected the main board from Power Board = backlight works.
                              2. Connected the main board and disconnected the T-Con = backlights does not work.
                              So I ordered a main board from Ebay also BN41-02156A but from...
                              01-18-2024, 06:56 AM
