Find substitute for mosfet in servo board of versacamm sp-540v plotter
  • edugimeno
    • May 2017
    • 581
    • Spain
    Hi There!
    I am currently serviciing a plotter versacamm sp-540v
    I found a shorted mosfet labeled J553 which corresponds with SJ-553s (surface mount)
    Neither local stores nor other webpages that are able to provide it before 1 month (only aliexpress, with 1 month delivery) can provide this part
    I need to find a substitute for it. Can anyone give me a hint on a part that I can use to replace it?
    Also, given the schematic Im attaching (pg 36, transsitor Q1) , does it make sense that the whole machine won't turn on when I press the POWER button on the panel? This part serves as a switch to start the heater so this kind of explains the spark I get as soon as I plug the PS DC wire to the board (indicating high current flowing even when powered off) but not sure if this makes sense with not being able to start the whole machine.
    Thanks everyone in advance!
  • R_J
    • 9606
    Re: Find substitute for mosfet in servo board of plotter
    Check the fuses on the main board (page 30) one may be open. looks like they (vhv0,vhv1) supply +41v for the head drivers, If the fuses are ok it might be just the mosfet that shorted.
    • edugimeno
      • May 2017
      • 581
      • Spain
      Re: Find substitute for mosfet in servo board of versacamm sp-540v plotter
      Not sure if I checked them all but visually (on the board) I checked all the fuses I could see and they all were OK. Thanks
      • edugimeno
        • May 2017
        • 581
        • Spain
        Anyway can I just use ANY P-Channel mosfet with
        • Vds>60v
        • Vgs>20v
        • Id>30A
        • Gate Drive=4v
        Being just a basic switching control gate to turn heating ON or OFF, which probably happens just once at the beginning and at the end of the printing process, I don't expect to have to meet other specs related to high frequency, max speed, etc, right?
        Thanks!
        • R_J
          • 9606
          Almost any mosfet with those specs should be ok, it is just used as a switch, any 60v or higher, 30 amp or higher should be ok. If it was in a smps or a similar circuit, frequency etc could be an issue, but that's not the case here.
          • edugimeno
            • May 2017
            • 581
            • Spain
            Awesome, some parts selectors like RS allows to filter with all those parameters so I got some candidates, thank you!
            • edugimeno
              • May 2017
              • 581
              • Spain
              MM sill having issue identifying some specs. Do I need to care for Vgs(th)?
              These MOSFET seems to trigger at 2-4v, is this normal? Do I need to select MAX Vgs=4?
              If I don't select that I get many more results
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8703
                You will rarely if ever find a mosfet with Vgs > 20V, in fact most mosfets 20V is the absolute maximum before you start destroying them (usually 30V or so is when you really start blowing them though).
                Vgs characterization depends on the circuit driving it, and for replacement it must pretty much match the original else you may run into operational problems.
                • edugimeno
                  • May 2017
                  • 581
                  • Spain
                  Ok but about Vgs(th) the original mosfet states:
                  "4v gate drive device"
                  Does this mean it will need at least 4v to trigger? Or is this the maximum? Or is this just a frequent value so I can discard it?
                  I have attached the full triggering circuit, it comes from a 41v PS thru what to my limited knowledge seems like a 1/3.2 voltage divider which would deliver 12v??
                  I would appreciate some help here
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8703
                    Now that I see the schematic, I think you best choose an identical device that closely matches the original due to the preheat circuit. This is a very poor design as the circuit depends on the characteristics of the device to operate the same as before. If you don't care about the preheat/slow power on then you can go ahead and use any p-ch mosfet there that meets the drain current requirements. TBH the preheat is probably what killed the device in the first place...
                    • edugimeno
                      • May 2017
                      • 581
                      • Spain
                      Well I don't know if the preheat os slow heat function is used....But I don know that an identical-closely alike Q for this one is being impossible to find.
                      If ANY P-Channel that goes beyond 30A will work and I don't need to care for that "4v gate" spec, I will go ahead as Im totally stuck on this repair...
                      Thanks!!
                      • edugimeno
                        • May 2017
                        • 581
                        • Spain
                        Ok this board is giving me more issues, I put it back today into the machine, without Q1 at all, expecting that despite the heating wouldn't work, at least the machine would some osme signs of "life", but it didn't go lthat way...
                        I will open a new thread as this is now a different matter, if those who provided help here want to take a look at it.
                        Link to new thread: https://www.badcaps.net/forum/showthread.php?p=1176211
                        Thanks!
                        • Xiran
                          Mosfet 28N03 substitute
                          by Xiran
                          Hi to all!
                          I want to know, if somebody knows, with wich mosfet can i replace 28n03 (i´ve didn't found it like that)
                          VDS= 30 V, ID = 28 A RDS(on) < 18mΩ @ VGS = 10 V RDS(on) < 30mΩ @ VGS = 4.5V
                          Thx in advance!...
                          10-06-2025, 06:42 PM
                        • Blastsail
                          Help find compatible MOSFET from Asus FA506 DABXBMBAD0
                          by Blastsail
                          I have a coffee damaged asus laptop with shorted mosfet for vram. Trying to find replacement but I am struggling to. Markings are M3966M and I have attached image of mosfet. Schematics are available which say chip is a QM3966M6 but i am unable to find this chip no matter what combination of letters i put in. I can see there exists an m3966m3 chip but this appears to be the wrong size and markings are different.
                          I have attached schematic as well to help, mosfet is on page 44 of pdf. I do not know where to start to find a compatible mosfet so any help will be greatly appreciated....
                          05-07-2022, 07:35 AM
                        • Jane
                          How do you test MOSFET in laptops ?
                          by Jane
                          I tried to use this method:
                          Testing an N-channel MOSFET:
                          Step 1: Discharge the Gate (turn off the MOSFET)
                          Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                          Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                          Step 2: Charge the Gate (turn on the MOSFET)
                          Now, place the red probe on the Gate (G) and the black probe on the
                          09-27-2024, 03:31 AM
                        • Oliver111
                          Asus UX535L.Help to find name of mosfet driver
                          by Oliver111
                          Hi! Please help to find mosfet driver name. Laptop is Asus UX535L. CPU PWM - NCP81215D, Mosfets on CPU - fdpc5030sg. Driver - DYU or DYP, cannot find it on google....
                          04-08-2024, 07:47 AM
                        • edugimeno
                          Repair Versacamm SP-540V that won't turn on
                          by edugimeno
                          Hi everyone! Hopefully someone can give a hint on this issue.
                          Trying to help my cousin who is a designer and is completly grounded since this machine stopped working
                          This is a large size plotter. He said he never turns it off, until one day he had to. When he tried to turn it back on, nothing happened....There is one LED in the MAIN board that's on all the time, and also the Ethernet board seems to be alive as it does detect the presence of the wire and flashes green and orange correspondingly
                          There is a PS board, pretty simple, only provides +41v, which is...
                          10-31-2022, 12:46 PM
