Ricoh mpc2051 utf8 error
  • jougounou
    • Jul 2014
    • 185
    • niger
    Hi
    everyone, need help for my ricoh mpc2051 displaying utf8
    how to solve this issue
  • Sus256
    HISENSE 65E7KQ PRO - no boot
    by Sus256
    Hi all!
    HISENSE 65E7KQ PRO
    RSAG7.820.13512 - chassis
    MT9618BAATAB - cpu
    RSAG7.820.12059 - power
    HD650Y3U77 - panel
    KLM8G1GETF - emmc
    Replaced emmc.
    Terminal log
    UART
    AC_ON
    E-B
    FDE enabled
    06-01-2025, 02:11 AM
  • AJ847.63e
    Has anyone Managed to ever solve DFU Restore error AM Restore Error Domain error75?
    by AJ847.63e
    Hi All,
    Judy doing some research on whether anyone's ever been able to resolve this. Seen quite a few examples and most have just gone eh guess it's dead, but surely there's something we can try?
    For instance, I'm working on a 2020 now with this error. Logiwiki says error 75 occurs when the system is in recovery mode but when I connect it to apple configurator it does show up as DFU so that doesn't seem right. When I try to restore it gets up to step 4/4 and the bar gets to the S of system then that's where it gives that code. Apple configurator then sits on "apple...
    06-02-2023, 12:12 AM
  • Superbee_dad
    Sharp 80” long short flash backlight error - Help
    by Superbee_dad
    Hello Sharp TV experts
    Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
    > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
    > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
    01-24-2025, 11:51 PM
  • Curtissimo
    HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
    by Curtissimo
    Hi everyone.
    I have a HP Elitebook 850 G8.
    Serial: 5CG2324XM0
    ProdID 6L8D5EC#ABA
    It has a Winbond W25Q256JVEN Chip.
    I need to remove BIOS Password.
    I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
    Attached my dump.
    I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
    I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
    What I did:...
    08-26-2025, 04:42 AM
  • Maalobs
    Philips 60PFL8708S/12 - QFU1.2E LA - Error code 53
    by Maalobs
    I have a 2014 vintage Philips 60PFL8708S/12 that suddenly died in the middle of the kids watching a show.
    The relevant service manual for the chassis is available here.
    The TV no longer powers on, and leaving it powered on for a few minutes results in the layer-1 error with 2 blinks.
    When I short the SDM to ground I get the layer-2 error code 53.
    The inside of the TV has no damaged components and no swollen capacitors.
    In SDM-mode when all the power rails are left on despite entering the protection mode, I tracked down and measured...
    04-02-2019, 01:15 PM
