Fujitsu fi-5120c error E2
  • c21yves
    SFCT
    • Oct 2018
    • 5
    Do someone know how to fix this error?
    I have 3 of those babies with the same error code and cannot find nothing in sgoogleling this
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Fujitsu fi-5120c error E2
    E2 is "Trouble in the optical system (front)."
    I'd start with cleaning the optical system.
    • Sus256
      HISENSE 65E7KQ PRO - no boot
      by Sus256
      Hi all!
      HISENSE 65E7KQ PRO
      RSAG7.820.13512 - chassis
      MT9618BAATAB - cpu
      RSAG7.820.12059 - power
      HD650Y3U77 - panel
      KLM8G1GETF - emmc
      Replaced emmc.
      Terminal log
      UART
      AC_ON
      E-B
      FDE enabled
      06-01-2025, 02:11 AM
    • angel35
      Fujitsu D3445-K11 Random BSOD ACPI BIOS ERROR in Windows 10
      by angel35
      An skylake (H110) Fujitsu PC mothardboard (D3445-K11) somethimes can't start...Appear BSOD ACPI BIOS ERROR in Windows 10
      (like below picture)
      What can cause somethimes ok, somethimes not good ACPI state? Really strange
      If ACPI not good the Bios missing information from SMbus like FAN speed Voltages etc
      Wong Bios IC? Power problem?
      Wrong status:
      Good status somethimes:
      07-27-2024, 04:04 PM
    • Superbee_dad
      Sharp 80” long short flash backlight error - Help
      by Superbee_dad
      Hello Sharp TV experts
      Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
      > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
      > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
      01-24-2025, 11:51 PM
    • TacticalFahrrad
      [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
      by TacticalFahrrad
      I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
      06-30-2025, 04:09 AM
    • Maalobs
      Philips 60PFL8708S/12 - QFU1.2E LA - Error code 53
      by Maalobs
      I have a 2014 vintage Philips 60PFL8708S/12 that suddenly died in the middle of the kids watching a show.
      The relevant service manual for the chassis is available here.
      The TV no longer powers on, and leaving it powered on for a few minutes results in the layer-1 error with 2 blinks.
      When I short the SDM to ground I get the layer-2 error code 53.
      The inside of the TV has no damaged components and no swollen capacitors.
      In SDM-mode when all the power rails are left on despite entering the protection mode, I tracked down and measured...
      04-02-2019, 01:15 PM
