Canon 350D Compact flash pin missing!
  • stevo1210
    • Oct 2006
    • 4156
    Hi Everyone,
    Just picked up a bargain bin special at my local pawn broker yesterday. An older Canon 350D DSLR camera for $50. I originally only wanted the 18-55mm lens as they are worth a bit and then trash the rest of the thing, but now I feel it's a bit of a waste if I did.
    The compact flash card slot has a broken pin, as in it broke completely off and is missing. It's one of the pins of the larger edged side of the CF card rails (pin 1 or 26???).
    I dunno what these pins do, but I inserted an old CF card in and it reads/writes fine to it despite missing pin! Curious to know... if I keep using it with a missing pin, what could happen? I think the missing pin might be a ground pin (since theres a few of those on the pinouts).
    Thanks.
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: Canon 350D Compact flash pin missing!
    looking at google images pin 1 is gnd pin 26 is cd1
    https://allpinouts.org/pinouts/conne.../compactflash/
    • stevo1210
      • Oct 2006
      • 4156
      I'm not sure which one it is to be honest as some diagrams confuse me online. Some say it's pin 26 and some say it's pin 1? What exactly does CD1 do? I know what ground does but not CD1.
      I am more inclined to say it might be a broken ground pin as it still works without flaws when tested with a card.
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        found this
        -CD1, -CD2. (PC Card Memory Mode). O. 26, 25. These Card Detect pins are connected to ground on the CompactFlash Card. They are used by the host to determine if the card is fully inserted into its socket.
        • Kg74
          • Feb 2013
          • 67
          • Usa
          If you want to replace the pin here is what I have done. Open up the camera, plenty of write ups if you search the net. You need to keep removing parts until you get to the compact flash board. Once removed you need to get access to the pins - if I recall you may have to desolder a metal shield. Find some old scrap component that has similar pins of the same thickness and remove a pin as large and undamaged as possible. If I recall the pins are soldered to the board and then go into a plastic holder. You have to desolder the broken pin and pull it out, then solder the transplant pin in after sending it to the plastic holder. If your camera does not have this set up or you can not find a long enough pin, I have just soldered at a joint, and then covered the joint with silicon. It is a pretty small working area, but I have done it three or four times and all the cameras, some over eight years, are still working.
          To be honest I have bought four broken cameras for just the lens, and replaced two with broken/bent pins and two with fuse issues.
          • stevo1210
            • Oct 2006
            • 4156
            Well the CF card slot still worked upon testing a few days ago (got a charger for it). Reads and writes no issues. Ended up selling it to a mate for $50 and he is happily shooting now with a 32GB CF card! Must have been a ground pin missing.
            • abajor
              Canon VIXIA HF S10 A read data from inernal flash memory.
              by abajor
              Hello I've had somebody bring in one of these charming little cameras to attempt retrieving data from the internal 32GB flash.
              Something is damaged inside the cameras lens assembly I can hear it clunking around and it has probably dislodged the sensor, powering up the camera gives a blank screen and the focus motor sounds like it's having a fit.
              The camera will not connect to a computer via USB in this state, I have no options no navigation, just power up and focus/zoom motor noises.
              I think my best shot is to figure out a way to read the internal flash memory outside...
              07-20-2024, 12:04 AM
            • bamdad61
              Canon DR-1210C flash dump request
              by bamdad61
              Dear folks, recently got a canon dr-1210c and it worked perfectly just for one day. Right now it shows all possible errors on the screen and do nothing. I tear down the device and found a 32 pin plcc flash chip. I thought reprogramming firmware might be helpful. The firmware update file from canon support include a dll file which doesn't help. So if anyone has the dump it would such a great favor to share.
              04-15-2025, 02:43 PM
            • corrize
              Nikon D800 camera - flash don’t work and capacitor don’t charge
              by corrize
              Hello, I'm stuck in troubleshooting…
              The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
              In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
              When I press the flash button, it's detected by the system, flash icon appear on LDC display....
              10-01-2022, 10:02 AM
            • liquidzorch
              DSLR canon sl2 flash error 50
              by liquidzorch
              Hello. I repaired a canon sl2 for personal use, it had a bad sd card slot, bad battery connector, plus a little bit of water residue on the motherboard. The water damage seems to not have caused any damage, just salt deposits that have been cleaned. After repairing everything works except for the flash.
              When shooting with the flash turned on, i get a "wait" message once, then on the second try I get an error: e50. I have disassembled the front to get a look at the flash board, and everything seems good, the flash board also controls the shutter, which works, so it does...
              02-17-2021, 05:24 PM
              ACER Veriton VX2640G-I3710 COMPACT DT Veriton X i3-7100 Specification for Upgrade or Repair
              This specification for the ACER Veriton VX2640G-I3710 COMPACT DT can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Veriton VX2640G-I3710 COMPACT DT boardview and Veriton VX2640G-I3710 COMPACT DT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
              09-12-2024, 03:30 PM
