HP Laser Jet 4M &WXP - how to make papersource seletion working?
  • gonzo0815
    • Feb 2006
    • 1600
    i successfully ported a Sony Vaio VGN-N38L/w Viesta laptop to windows XP Pro.
    At the customers site, i installed an HP Laser Jet 4m with an USB > printer port adapter cable.
    The printer is working fine, but regardless what i choose at the printers driver options, it only took the paper from the lower paper tray.
    I know, that with the old system i managed it (for several years...) to install two logical printers from which the one sourced the paper from the lower tray, the other from the upper one.
    Sadly, the former laptop was stolen and i only have got the already formated disk (the thieves sold the complete equipment at ebay ;-) ) from the customer.
    I managed to get most of the data, but the c: partition has got a new Windows on it, thus i was not able to save it in a working condition.
    With the new system, the printer driver ignores any setting regarding the paper source and uses the lower tray, unless i pull it.
    I used the HP Windows XP PCL5 driver and the already included one from MS.
    Any help would be appreciated.
    May be the USB thing is making the trouble, but i don`t believe this.
    Any way, next time i took my old Omnibook 4150 with, which does have an native printer port.
  • kikkoman
    • Jul 2007
    • 691
    Re: HP Laser Jet 4M &WXP - how to make papersource seletion working?
    I have the LJ4, but I think it's the same driver package. So far everything has worked fine with the MS XP driver.
    Which one is the PCL5 driver? Is that the one from their support page? 'cause if I remember correctly there were only PostScript drivers in that package (which I don't need, and the XP driver is PCL anyway).
    "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
    • gonzo0815
      • Feb 2006
      • 1600
      The driver is from HP`s support site, it is dated from 2002 if i remember right.
      A quick search with Laser jet 4m and you get it and several.
      The driver package is labeled as PCL only, but i think this not important.
      May be this wired issue is really caused by this USB cable, i think it is best to try it with my old laptop or i try the serial port, which i think i have seen on the Vaio.
      How mutch trays does the LJ4 have? not sure, if the second tray is a extension.
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        might be right about the extra tray if so you will have to specify it in the driver settings.
        http://h20000.www2.hp.com/bizsupport...odTypeId=18972
        usb is either working or not working in my opinion.
        there is also issue of software settings, like in page setup / source but i dont believe that would be your problem
        • kikkoman
          • Jul 2007
          • 691
          the only driver i can find is the 4/5/6 PS driver (yes, from 2002).
          just checked with mine - the options show the lower tray no matter if it's actually installed or not.
          by lower tray i mean the big bulky thing that holds 500 sheets and sits under the printer (guess it's the same at 4 and 4m). the one that's labeled 'hohe kapazität'.
          when i tried the HP drivers there were a few issues - however i don't recall if there were any with the paper source - so i went with the MS ones.
          • gonzo0815
            • Feb 2006
            • 1600
            Yes will, thats exactly the way what i think about USB, but ATM i would not exclude it from the list.
            The PCL5 only driver is German only, you have to switch the language and you get two printer drivers.
            One is PS and the other is PCL5 only.
            May be i give the PS driver a try.
            Regarding the trays, i think there are only two plus the manual paper feed.
            So i think i have to disable the "hohe Kapazität" thing.
            But IMO this dosn`t mater.
            The problem is, that even if i print something from Word and specify the paper source prior to printing it is getting ignored.
            Only manual feeding is recognized by the printer.
            • Curious808
              Brother HL-2140 laser printer: printer error (solved)
              by Curious808
              SOLVED. I removed the printer in settings, replugged and let it reinstall and it worked this time.
              Windows 10
              Attempt to print and immediately get a Windows pop-up saying "Error printing". The document appears in the printer queue window with Status "Error-printing".
              Turned off printer. Unplugged, waited, replugged. Ran the Windows troubleshooter. Removed and reinserted toner cartridge. Checked for paper jam. No printer error lights. Reinstalled driver. Restarted the Spooler service. Rebooted...
              06-22-2023, 11:11 PM
            • re-atari
              Anycubic Photon 5.5 3D printer 25Q32 flashrom dump needed
              by re-atari
              Hello all, as the title says, I'm very much in need of a valid firmware dump of a Anycubic Photon 5.5 3D resin printer. It's stored in a Winbond 25Q32, so it's 4Mbyte.
              Here's a little background for my request. A few weeks ago I bought this 3D printer from a guy who had moved on to a PLA printer. I got it at a vey reasonable price, as it was in a defective state. The seller told me that he had experienced a power failure during a firmware upgrade, after which the printer appeared to be dead. He thought the firmware was corrupted in such a way that the printer was now bricked. As he...
              02-03-2025, 06:49 PM
            • osrex
              LED DRIVER KEEPS DYING
              by osrex
              Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
              i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
              i have no datasheet at all for the LED lights, all i have is its length.
              long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
              as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
              05-05-2025, 03:36 PM
            • aboumohamed
              good dumps fo BROTHER HL-L2310D laser printer
              by aboumohamed
              good dumps fo BROTHER HL-L2310D laser printer...
              11-13-2023, 04:35 AM
            • nervous_capybara
              Repairing the Hitachi DA-6000 CD player
              by nervous_capybara
              Hello everyone !
              I recently conducted maintenance on a Hitachi DA-6000 CD player for my grandparents : it had two distinct issues.
              Feel free to share your experience if you ran into other issues.
              DISCLAIMER : BE VERY CAREFULL WHEN OPERATING ON THIS SYSTEM : THE HIGH VOLTAGE IS VERY CLOSE TO THE VARIOUS TESTING POINTS, PROCEED WITH CAUTION
              CD tray would not come out of the player
              I could hear a motor spinning inside the player but the CD tray would not come out.
              Turned out that the issue was the CD tray belt that aged poorly and began to...
              11-05-2025, 03:11 AM
