Need Nochip_firmware_pantum_M7100_M6700_M6800
it gives out the same
[18.09.2025 8:27:19] : Model: M7100DN
[18.09.2025 8:27:20] : SN: CD3S032598
[18.09.2025 8:27:22] : DDR MemSize: 256
[18.09.2025 8:27:26] : Firmware Version: 2.A.1.3
[18.09.2025 8:27:27] : Engine Version: 2.A.1.3
ID:
Q0QzUzAzMjU5ODo6MkEwNTIxMDQ6OkFDOkM1OjFCOjNEOkVGOkU2OjoyLkEuMS4zJFNJRzYyNDYwYj
NhZjgwMjkyZjU3NTI2MTJmZmZmNTk5ODZhOjpEQVRBOjIwMjLlubQgMDbmnIggMTDml6Ug5pif5pyf5L
qUIDE0OjQxOjM5IENTVDo6MjU2OjpNNzEwMEROADo6Mi5BLjEuMwA6OjUuODo6
вот может быть этот ID:
qUIDE0OjQxOjM5IENTVDo6MjU2OjpNNzEwMEROADo6Mi5BLjEuMwA6OjUuNzo6Comment
here's your firmware
Hello!!! Can u help me? Pantum M7100dw?
id:
Q004VVYwMENOUzo6MkMwNzIxMDQ6OkFDOkM1OjFCOjZDOjAxOkRBOjozLjYuMy4xJFNJRzYxYmM4MDQzNDI0NWMzYjE1MjBjZWZiMGRjODhkNDZlOjpEQVRBOldlZCAxMCBNYXkgMjAyMyAwNjozMDo0MiBQTSBDU1Q6OjI1Njo6TTcxMDBEVwA6OjMuNi4zLjEAOjo1Ljg6Og==
thank you in advance!!Comment
here's your fixware
id:
Attached FilesComment
			by Mr.heinrichGreetings, i just have a problem with printer HP deskjet 3835, this printer using F5R96-60004 board. Can you guys help me to get bios firmware that support for this type. i have searching this bios firmware at google but i can found it. help me plz. thanks.06-07-2024, 08:17 AM
			by zklgfsHi,
I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...-
08-11-2025, 02:14 PM -
			by TheUserHello to everyone ,
This is my first post here, and i would like to share with you a small story in case you can help me.
Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help... -
			by gurj1979Hi guys.
I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
Got New chip and writes good.
THE PROBLEM...
It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
Does anyone have a Good Firmware I can have?...-
							Channel: Troubleshooting & Designing Networks
			by Curious808SOLVED. I removed the printer in settings, replugged and let it reinstall and it worked this time.
Brother HL-2140 laser printer
Windows 10
Attempt to print and immediately get a Windows pop-up saying "Error printing". The document appears in the printer queue window with Status "Error-printing".
Turned off printer. Unplugged, waited, replugged. Ran the Windows troubleshooter. Removed and reinserted toner cartridge. Checked for paper jam. No printer error lights. Reinstalled driver. Restarted the Spooler service. Rebooted...06-22-2023, 11:11 PM - Loading...
