brother j132w paper jam
  • zakaria23
    • Jun 2019
    • 4
    • annaba
    My Brother j132w is stuck on the paper jam issue, and yes i have checked for stuck papers but nothing there. Im thinking its a software related problem, any help?
  • aboumohamed
    • Dec 2018
    • 259
    • algeria
    Re: brother j132w paper jam
    check paper sensor
    • zakizaki2015
      • Nov 2023
      • Algeria
      Clean the carriage encoder
      • bseinfo
        Brother MFC-J480DW printer stuck in maintenance mode
        by bseinfo
        I have a Brother MFC-J480DW printer stuck in maintenance mode (BHL2 USB Maintenance). The screen only shows white bars, and it’s completely unresponsive. The official Firmware Update Tool doesn’t detect it, and I’ve tried multiple versions.
        I’m looking for the raw firmware file LZ5313_L.blf (or .djf), compatible with FILEDG32.exe, so I can attempt a manual recovery.
        If anyone has a full dump of this model (or a compatible one like MFC-J485DW or J885DW), or knows a private Discord or Telegram group where this kind of firmware is shared,...
        07-05-2025, 10:53 AM
      • Raymond red (mon)
        Brother J2730-DW stuck on Brother Logo
        by Raymond red (mon)
        hello, I have this Brother J2730-DW printer that was brought to me by a friend, it was supposed to be converted to continues ink but the printer wouldn't turn on completely. The printer powers on and plays a tune but it gets stuck in the brother logo. Upon checking, the printer was infested by many small cockroaches. I do checked the board cleaned and tested some corroded capacitors but all seems to be fine, I couldn't find any short circuit or any missing component on the board. Also checked the power supply and it was working fine.
        please help.
        11-08-2024, 09:19 AM
      • Stunt
        Hp Laptop Stuck on Hp protected by hp sure start screen
        by Stunt
        Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
        I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
        I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
        Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
        screen that's it and stuck there. I left it until the following day and i still...
        09-02-2025, 01:51 PM
        HP ProDesk 400 G2 Mini + 2x Pro Slate 8 Paper Folio ProDesk 400 i5-6500 Specification for Upgrade or Repair
        This specification for the HP ProDesk 400 G2 Mini + 2x Pro Slate 8 Paper Folio can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 400 G2 Mini + 2x Pro Slate 8 Paper Folio boardview and ProDesk 400 G2 Mini + 2x Pro Slate 8 Paper Folio schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
        09-12-2024, 03:28 PM
      • stormanimal83
        Gigabyte B450 Aorus Pro stuck at VGA LED, burning hot LED Controller MCU 1 under PCI slot...
        by stormanimal83
        Hey....
        Board as written in description was stuck at VGA LED. common Problem wit these type of bords.... tried all the "standard stuff" like resettin... reseatin.... found out the LED Controller MCU1 = IT8295FN-56A geting burning hot under the last PCI Slot.. now i desoldered it cause there were only 18 ohms at the caps arround.... another aorus x470 in working condition with similar part and nearly same layout had arround 280 ohms...
        my question is: why doesnt the board start know without this chip.... worked myself through the boardview but i can´t understand...
        01-18-2024, 02:15 PM
