First arcade machines to use switching (not linear) power supplies
  • japlytic
    • Oct 2005
    • 2086
    I am curious about what were the first arcade machines which used switching power supplies for the main logic (not the monitor).
    If you know of any (the earlier the better!), please list them here.
    • 31304
    Re: First arcade machines to use switching (not linear) power supplies
    first factory job was atari i-robot i think - 1983.
    http://www.ionpool.net/arcade/irobot/irobot.html
    very over-engineered and built like a tank.
    (i own one - they are very rare! )
    linear psu's are more reliable in long-term situations, so switchers only came into use when the games started to need more than 4-5A of power.
    there are williams defender machines built in 1980 that are still running today that have never had the linear psu touched.
      07-01-2024, 06:34 AM
      03-31-2024, 02:12 PM
      Meanwell Switching power supplies intermittent every capacitor under 100uf
      Here is the eBay website link where I bought them from
      https://www.ebay.com/itm/276135936202
      I have been waiting for these switching power supplies to come well they came in today so I took one apart and found that it Capcon and EIite and another brand that is on my list of capacitors to replace on site it has several 0.47uf @ 50 volts ESR value twice the reading of a new one 10 UF @ 50 volts almost twice the ESR value of a new one 47 UF @ 59 volts with double the ESR value 100 UF almost the same as a new one it got replaced for good measure Iit was a brand if I see them...
      11-25-2023, 06:05 PM
      After all of...
      07-13-2024, 08:14 PM
    • Per Hansson
      WARNING: Live heatsinks & single pole on/off switches in switching power supplies
      by Per Hansson
      This is a warning to inexperienced and experienced techs alike:
      The De-facto standard is to have the primary side heatsink live in switching power supplies.
      That is the primary side heatsink is referenced to the negative of the bulk filtering capacitor.
      Therefore never ever touch the heatsink if the device is plugged in.
      And even if it is unplugged let the capacitor discharge first!
      Another really serious concern is that the power switch also by De-facto standard is single pole.
      This means it only cuts power to the phase or neutral (not both) depending...
      06-09-2021, 12:01 PM
