I've been trying to find a good SFX PSU with a 60mm fan. I think this may be exactly what I've been after.
The primary caps are 680uF Su'Scon (I know, not a great brand, but primaries rarely fail). Secondaries were a mix of Jun Fu and Fulltec, but I re-capped with Nichicon HE and Panny FC. It has two fans, a front and back (a bit like an antec smartpower). Both are temp. Controlled 60mm jamicons. It has a rectifier, rather than the 4-diode treatment and no missing components. The heatsinks are huge for an SFX (bigger than I see in some ATX PSUs), same with the transformers.
It's hard to read the numbers on the parts, given how crowded it is in there, although I was able to make out "GK2JC" on the primary switchers.
It looks like a Channel-Well OEM, as "CWT" appears in the part numbers on both transformers.
