hi..anyone knows any ic equivalent to apw9010? i am looking for the replacement of the fan controller ic..cant find the datasheet of this ic and also this item is no longer available! especially from aliexpress
ic equivalent to APW9010
Re: ic equivalent to APW9010
Is that the date code? It should be on the Anpec website somewhere. http://www.anpec.com.tw/index.aspx?lang=en -
tq ya..will have a look on the websiteIs that the date code? It should be on the Anpec website somewhere. http://www.anpec.com.tw/index.aspx?lang=enComment
thanks!Comment
by mrsdsdsdsdhi everyone i hope you all doing well.
i'm trying to replace a sim socket in my 4g router, i found similar parts on aliexpress and i'm not sure if it will work on my device (Huawei b593s-22)
here's the original one:
and here's the links of the one i found on aliexpress:
1-
https://www.aliexpress.com/item/1005...yAdapt=glo2vnm
2-
https://www.aliexpress.com/item/4001...yAdapt=glo2vnm
if anyone knows if it is possible to replace it with either one please let me know.
thank you...-
Channel: Troubleshooting & Designing Networks
by ary89i need to know equivalent and pin to pin similiarities for RT6575D, i have Asus ROG GL503 from 2017 won't charge and power on, 19v present, put the charger on and with thermal camera, that ic getting hot11-12-2025, 09:44 PM
by karloxGood evening, colleagues.
Does anyone know an equivalent or a compatible replacement for the uP9002P IC (power controller)? Alternatively, does it come under any other marking or code on different boards?
Any insight or cross-reference would be greatly appreciated. Thank you in advance!09-01-2025, 08:43 PM -
by peter_wheatHi All,
I'm looking for a SMPS flyback transformer TAM TO-5622, or equivalent, or any information on it? Company is Tamura Corp (https://www.tamuracorp.com). It has Primary, Secondary, and Auxiliary windings. Have emailed the company, but no info back yet. It is out of a Makita DC24SC battery charger.. This transformer has a burnt out the primary (caused by a failed MOSFET). Secondary, gave me a reading of 0.49 Ohms, and Auxiliary a reading of 0.93 Ohms. I took it to bits, thinking I might try and re-wind it, but it was more complex than I realized, and had difficulty removing... -
by khelaneHello
I wanted EQUIVALENT IC SOUND
---- ALC 3204 ----
Device
DELL 5400
TNX - Loading...
