Diagram for PS4 FAT CUH-1116A power supply
  • fab13
    • Dec 2021
    • 109
    • France
    I am looking for the PS4 Fat power supply diagram specifically
    for CUH-1116A series or older it will be fine
    Thanks lot =D
    • 31249
    Re: Diagram for PS4 FAT CUH-1116A power supply
    what psu model?
    i have diagrams for the ADP-240AR
    • fab13
      • Dec 2021
      • 109
      • France
      I have exactly the 'ADP-240AR' power supply where there was a blown NTC thermistor with fuse.
      Hence my topic here https://www.badcaps.net/forum/showthread.php?t=111907 where you answered me and I thank you very much.
      I'm a beginner in electronics for information
      • Saydi Alghifari
        • May 2025
        • indonessia
        Thanks lot
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
          03-31-2024, 02:12 PM
          07-01-2024, 06:34 AM
        • JimBanville
          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
          by JimBanville
          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
          09-13-2023, 07:21 AM
        • Andreas_de
          Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
          by Andreas_de
          Hello!
          i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
          Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
          Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
          04-12-2025, 10:38 AM
