Examination of Golden Field ATX-S628 550W peak power PSU
  • everell
    • Jan 2009
    • 1514
    Re: Examination of Golden Field ATX-S628 550W peak power PSU
    Brand new......should last a month or two. Yep.....or until that cheap 2 transistor 5vsb circuit goes overvoltage and takes out your mother board with it!
    Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
    • Newbie2
      • Sep 2005
      • 885
      I searched the model number ATX-S628 on Google to find more pictures of this power supply. It appears that Golden Field sells another version of their ATX-S628 PSU for the Chinese market, nicer in appearance and slightly different than the one they make to export (the ATX-S628 that I have).
      It comes in a silly looking light teal plastic tub with blue handles (which in my opinion is excessive packaging for a power supply), and has a 140mm fan (also making it slightly longer) along with all cables sleeved. The PSU I got came in a usual decent-sized cardboard box, equipped with a 120mm fan, and only the main ATX connector cable sleeved on the one that I have. The Chinese version appears to also have passive PFC (judging from seeing an inductor inside the front of the PSU in the pictures), and can only accept 220V AC. The one I have doesn't have any sort of PFC in it, and has a switch that can switch between 115 to 230V AC. I wonder if the Chinese ATX-S628 can also be found in Europe, due to power supplies there also made only to accept 220V AC.
      Here are the best pictures I could find of it:
      Even with these mainly cosmetic differences, the internals appear to still be the same (image from Golden Field website):
      My gaming PC:
      AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
      ASUS M4A77TD AMD 770 AM3 Motherboard
      PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
      G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
      TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
      WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
      ASUS Xonar DG 5.1 Channel PCI sound card
      Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
      Antec Three Hundred Mid-Tower Case
      Microsoft Windows 10 Pro 64-bit
      Microsoft Windows 7 Ultimate SP1 64-bit
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        They not only don't give you a switch...
        ... They slap a sticker over the hole for the switch...
        In China most shopping is done on foot-subway-bus. [Been there, done that.]
        Boxed PSU is a pain in the butt to carry around when you have other stuff to do.
        Maybe.... They think...
        If they give you an easy to carry tote then you might buy more at the PC shop.
        Mann-Made Global Warming.
        - Dr Seuss
        • Newbie2
          • Sep 2005
          • 885
          But wouldn't the shops have plastic bags to put stuff in, like they do here?
          My gaming PC:
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Would you put a hard drive in a plastic bag and tote it around all day?
            Especially as they usually come bare [no retail box] over there.
            I used to take duffel bag or a back pack with me because each place usually gives you a tiny bag just big enough for what you bought there. That way I could put all the tiny bags in my bag and only keep track of one bag.
            Remember I said -> .. Maybe.... They think...
            Got to be some reason they think it's a good idea.
            - Dr Seuss
            • Newbie2
              • Sep 2005
              • 885
              Sorry to revive an old thread but...
              This Goldenfield PSU has been reliably powering this system configuration since the start of August:
              Intel Core 2 Quad Q6600 2.4GHz quad-core processor (Socket 775)
              8GB DDR2-800 RAM (4x2GB dual channel)
              MSI P6N SLI Platinum motherboard
              Sapphire ATI Radeon HD5770 1GB GDDR5 PCI-Express x16 2.1 video card
              Maxtor DiamondMax 23 STM3500418AS 500GB SATA-II 3.5" Hard Drive
              Goldenfield S628 ATX Power Supply
              Microsoft Windows 7 Professional x64
              Antec Three Hundred mid-tower case
              Voltage readings from the motherboard are:
              +12V = 12.144V
              +5V = 5.003V
              +3.3V = 3.328V
              +5VSB = 4.944V
              All voltages are stable, no fluctuations. The computer runs perfectly.
              My gaming PC:
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                What is the ripple?
                - Dr Seuss
                • Newbie2
                  • Sep 2005
                  • 885
                  What is the ripple?
                  Dunno, don't have a good oscilloscope to check that. This is just serving as a temporary PSU while funds for a better one are saved up.
                  My gaming PC:
                  • Newbie2
                    • Sep 2005
                    • 885
                    BTW, this isn't one of my PCs, it's a relative's.
                    My gaming PC:
                    • peter21
                      BeQuiet Dark Power Pro P10 550W PSU: Missing 5V Standby
                      by peter21
                      Hi there,
                      a friend of mine gave me a BeQuiet Dark Power Pro P10 550W PSU.
                      The problem: The PSU simply switched off during operation and never came back on.
                      My observations / measurements:
                      I opened the housing and checked for obvious damage -> negative. Visually, everything seems fine.
                      Lowcost power supply tester (China):
                      No result. The power supply does not turn on and the tester keeps off
                      Next, I measured the 5V standby line (pin 4) on the ATX connector.
                      Result: Not present (!).
                      Obviously this seems...
                      02-24-2024, 10:11 AM
                    • lapfix
                      Dell latitude 5320 South peak 13 not power on.
                      by lapfix
                      Hello friends
                      Got this laptop dell 5320 not power on , just a fast and a dim blink amber light at the power on led indicator.
                      motherboard south peak 13 mb 213252-1
                      i'm using schema and Bvd similair to this motherboard. https://www.badcaps.net/forum/troubl...-latitude-5320
                      i don't have a type-c meter for the moment , so i m taking the voltage using his original charger.
                      As i undestand from many topic here ,...
                      04-29-2025, 06:22 AM
                    • Green Probe
                      Latitude 5530, 203102-1, South Peak 15 MLK MB DDR4, i5 12th Gen
                      by Green Probe
                      Hi, I'm looking for a schematic and/or boardview for a Dell Latitude 5530. The motherboard is marked "South Peak 15 MLK MB DDR4, 203102-1, FK8VG$LA" I think it's the i5 12th Gen. I'm trying the similar 5520 schematic, but things are shifted around, making it a bit tough for me to find things. This might not be the place to discuss the issue, it shows no life. It consumes 5V1A when plugged into the USB-C charger. Main rail is present at 16.75V, and 4.2V is present at some locations. Any help is appreciated. Thanks!
                      08-15-2024, 05:47 PM
                    • hypermk735
                      Lenovo Golden Key V3.5.60 - DMI EDITOR (BOOTABLE USB)
                      by hypermk735
                      Sharing the latest version of Lenovo Golden Key I found to change DMI information such as serial number, MTM, UUID. Run the U1 application and create a bootable USB. It may show an older version upon making the usb. Restart the program and it will update the USB to the next version available. For some reason the updater program does not upgrade all the way to the newest version, only incrementally until it reaches the latest. So do this, Open the u1.exe run the update, close the program, open and run again, close it and repeat until you get to the latest version 3.5.60....
                      04-09-2024, 06:39 AM
                    • expertreader
                      Dell 5520 South peak 15 MB 213253-1 2TWTT$LA
                      by expertreader
                      Hi, Looking for schematics and boardview please. laptop detecting only 5V at USB C so hoping for a short circuit....
                      10-18-2025, 09:44 PM
