another imac psu ADP-200DFB
  • rookieme
    • Oct 2014
    • 403
    • Greece
    hello, the power supply is in a working - not working state
    if switched off the 12V are dropping to 3V before going to 12V again - when you have 12V you can hear a electronic noise and when the voltage drops the noise stops
    the cycle repeats every 4-5 seconds
    well if you press the power button at the time you have the 12V system can boot and work fine so with load the PSU can work
    so far I have tested the capacitors at the 12V line
    any suggestions?
    • Jul 2011
    • 6070
    Re: another imac psu ADP-200DFB
    Check all capacitors that are less than 100uf with an ESR meter if you do not just results
    • rookieme
      • Oct 2014
      • 403
      • Greece
      thank you for the reply,
      by saying all capacitors you mean the electrolytic only or the polymer capacitors too?
        • Jul 2011
        • 6070
        I was referring to electrolytic ones
        I will check capacitors with my ESR meter but if I do not like the results that I am getting I do this test if I do not have this value on hand
        I will check the capacitor at 100*F then a room temperature then at 50*F if the results are more than 10% of a new capacitor between the the 100*F and the 50*F temperatures I consider them to be bad but this just me personally
        Here is what I do when I polymer capacitors and there are several of them with the same UF value and voltage rating if you have ESR reading all over the place more than 0.50 I would compare them to a new one and just replace them for good measure but that just me personally
        I use this rule when I repair Servo drive and switching power supply for these machines and have been able to get them back functioning correctly again but this is my personal experience with this type of testing capacitors for these devices
        • rookieme
          • Oct 2014
          • 403
          • Greece
          So far there is only one at 33uF.
          I have access only at capacitance meter so no way to measure the ESR.
          I have replaced it as it was metering at 30uF with no luck.
          Which is your ESR meter? Maybe I should consider buying one.
            • Jul 2011
            • 6070
            My is Anatek Blue ESR Meter from EBay there are two versions one is a kit and the other one is assembled which cost a little bit more and if I remember correctly this seller has both versions
            https://www.ebay.com/itm/18423015559...53.m2749.l2649
            Yea it is a little bit expensive but it is a good one and it has help me troubleshooting Servo drives and VFD drives and Switching power supply with capacitor issues
            A little while back I bought another one so I would have a back up tester for testing capacitors at a customer place of business because the one that I am using is a little rough around the edges from a lot of use
            If after you replace the capacitors in this switching power supply and you still have this issue then check the power supply rails for short circuit conditions to make sure that this not an issue
            • rookieme
              • Oct 2014
              • 403
              • Greece
              I have bought some years before this one but I'm not sure if it is trustworthy
              https://www.ebay.com/itm/28475083100...0AAOSwlb5iTpf7
              • rookieme
                • Oct 2014
                • 403
                • Greece
                Thank you for your assistance I managed to repair it.
                There was a cap 100uf under a heatsink that was measured 73uf and 6,5 Ohm ESR!
                I should start using my meter more often too.
                • dmcabs
                  SHARP LC-60LE640X display flashing white noise patches and totally dropping out randomly
                  by dmcabs
                  Hey guys,
                  I have a SHARP LC-60LE640X TV that has suddenly developed an intermittent fault of flashing white noise patches (appears like an Analog tuner off signal) and then totally dropping out.
                  This model I believe is also known as LC-60LE600U or LC-60LE640U in other regions.
                  FYI, a long time ago I was a component level repair tech for all consumer electronics and IT equipment.
                  I'm a bit rusty but still have ability to dig right down.
                  I measured all power supply lines and checked them for AC ripple voltage. Noting any lines that exceeded about...
                  09-21-2024, 11:09 AM
                • tony359
                  by tony359
                  11-28-2023, 05:18 AM
                • MegaZAC
                  Onkyo TX-SR805 noise in one channel
                  by MegaZAC
                  Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                  Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                  There's some logic behind it. As soon as I select an input I get only left...
                  04-23-2025, 10:09 PM
                • hackymc
                  iMac 27 Late 2013 - Fan noise , OS very slow
                  by hackymc
                  Hello i have an iMac late 2013, after GPU reflow, the fans are loud and iMac is working very slowly, i try to reflow smc too , and same problem. Anybody have an ideea or a resolution.
                  I try apple diagnostics and error from SMC PFM006.
                  SN : DGKMQ0FVF8JC
                  EMC : 2639
                  07-01-2022, 08:20 AM
                • ryogadan78
                  iMac A1418 - No LED, no power after overvoltage on Ethernet port
                  by ryogadan78
                  Hi guys, I need your help again.
                  I have this iMac from a customer that shut down during a storm along with all the other devices in the house. In particular, the router, connected via Ethernet to the iMac, caught fire.
                  When I removed the screen from the iMac to check the status of the LEDs, I noticed that none of them were lit. I had a perfectly compatible and working power supply, so I tried it right away, but the problem remained the same (no LEDs). With the thermal camera, I noticed only a slight warming (32 degrees) of the NCP1605BG chip on the power supply. The rest was completely...
                  06-10-2025, 03:49 AM
