Snap, crackle, and fart....
  • everell
    • Jan 2009
    • 1514
    New project, a Dell Model L350N-00 350 watts. Opened the case and found four bulging capacitors. So removed the pc board from the case and replaced the bulging capacitors. Then applied power to check out the power supply. All voltages came up fine. So I sat back looking at my newly repaired psu, and about two minutes after power up, there was a bang, crackle, sparks flying. I shut off the power and sat back looking at my newly fixed wreck, wondering what happened when I began smelling paper burning. Didn't see anything......so lifted up the power supply pc board and the paper it was sitting on was on fire! A small fire which I quickly extinguished, but a fire none the less. So I sat back looking at the mess......WOW!!!
    Guess I better take a look see and find out what happened. Smoke covered about 75% of the bottom of the board. So I got out the alcohol and brush. It cleaned up well, so well I couldn't see where the damage was. Thinking the sparks probably came from the switching transistors shorting, I measured them with ohm meter. Everything looked good. Checked 5vsb power transistor...also good. Checked the output diodes.....all good. Checked the fuse....also good. What in the world is going on???
    On one corner of the bottom of the pc board, the manufacturer had put a bunch of that white silicon stuff, then attached a piece of plastic about one inch by one inch. I suppose this was to prevent arcing to the case. So I decided to remove it. As I was pulling the plastic away, the white stuff started crumbling, and throughout the white stuff were small black pockets. Using screwdriver, I scraped away all the white stuff, then cleaned the board with alcohol. All that was covered was the snubber for the main switching transistor. The protection diode was shorted, and the filter capacitor 2.2 uF 450 volts was very high esr, and the filter resistor checked out OK. Some of the circuit trace had been blasted away.
    With pc board cleaned up and damaged parts removed, I decided to try powering up without the snubber - as it is only a protection circuit. I turned on power, and the power supply came up just fine. All output voltages normal. Then shut down power as I do not like running without the snubber.
    Root cause analysis of this failure: The white stuff goes conductive with age and causes some power supplies to go ........ snap, crackle, and fart (err....pop).
    Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
  • 370forlife
    Large Marge
    • Aug 2008
    • 3113
    Re: Snap, crackle, and fart....
    Enermax had this problem a while back. I guess lite-on did too. Glue gets old and hot, gets conductive. The silicon type glue as well as hot glue that the cheaper companies use doesn't do this.
    Delta actually doesn't use glue anymore in their assembly, they make steel weights that are shaped so they hold down as many parts as possible while going through soldering. Smart as they can be constantly reused and money is saved on glue.
    • everell
      • Jan 2009
      • 1514
      Not only does the glue get conductive over time, it is also corrosive. Here is a picture showing a diode which was completely covered with the glue. The glue had turned almost black. After removing the glue, you can see the greenish color on the diode lead which is copper oxide. This psu is a recently acquired Bestec ATX-250 12E.
      • Scenic
        o.O
        • Sep 2007
        • 2642
        i've seen older fortrons that failed to start up..
        the PWM controller was partly covered (pins) with that crappy glue... turned dark brown and got conductive, and the PWM controller got totally out of whack, preventing the PSU from starting up..
        well.. at least better than having fried fets/diode-packs because of that glue i guess
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          i guess that psu is a pyro... might explain the liteons i ave had go funky... i had one that wasa claimed lighning hit, the person even got insurance money back on it, but i know it was a liteon unit and i bet it made the power go funky when it blew. second worst charring after the burnt bestec 12e i had charred... damn 5vsb circuit...
          i have a couple still, i better pull the psu's out of use until i can get the glue cleaned off.
          sigpic
          (Insert witty quote here)
          • hikomalek
            SYMSI70 gas heater, TOP247Y exploded, power supply, snubber network
            by hikomalek
            Hello, I have a SYMSI70 gas heater board, which has issues with its primary side power supply, controlled by TOP247Y chip.
            When I replace a TOP247Y it explode in 1 second. I have desoldered transformer and measured a winding ratio, so transformer looks like OK.
            Transformer:
            |Info| Primary | Aux | AB | CD|
            |Ratio|1|25|40|12|
            |Voltage AC|230V|9.2V|5.8V|19V|
            |Voltage DC (*1.41)|230V|13V|8.1V|27V|
            I have disabled a undervoltage protection of TOP247Y, disconnected secondaries and tried to power it up...
            09-19-2025, 03:30 AM
          • mitsu2k
            The Real Dangers of conductive glue.
            by mitsu2k
            I know many folks on this forum warn against conductive glue and suggest removing it immediately upon site. I'm here to vouch and say these people know what they are talking about. To be more accurate, the glue isn't intended to be and doesn't actually start out conductive. It gets conductive as it is heated by components that get hot. The glue starts out to be a light tan color but as it is exposed to heat, it gets darker and darker until it is a dark brown. I have found that it becomes conductive at the point that it reaches a light brown color on darker.
            Here is an experience I...
            04-16-2023, 06:29 PM
          • acedogblast
            by acedogblast
            11-02-2024, 05:13 PM
          • howardc64
            Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
            by howardc64
            TV was fixed just after removing Samsung's rear snap cover.
            This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
            Maybe PSU->backlight connector didn't have a good contact?...
            07-23-2025, 12:34 AM
          • digtalhd
            Remove IC glue
            by digtalhd
            Hi!
            Anybody help me. Remove IC glue on mainboard.
            Thank you....
            11-08-2024, 02:25 AM
