Power Mac G4 MDD "Mirror-Door" won't power up
  • AtariMan
    • May 2019
    • Russia
    #121
    Re: Power Mac G4 MDD "Mirror-Door" won't power up
    Thanks everybody. I managed to fix my MDD G4
    • falcontech
      • Oct 2013
      • 470
      • italy
      #122
      Hello
      I also have the same problem with two power supplies of these samsung, I am changing all the components that are attached to the main heat sink for safety, I am also changing the large capacitor and I would also like to change the rectifier bridge, but with the number that is there above I can not find anything, someone can tell me the characteristics to put one like it thanks
      • falcontech
        • Oct 2013
        • 470
        • italy
        #123
        Originally posted by luvtrumpsh8
        These are a fun fix. I haven't read this thread but used to work for a company doing these. The ACBEL was always caps, the 1000uf was the main prob not allowing it to start up, but good to do the others while you're in there, and the samsung ones were a little more difficult. it was always a diode or two and the mosfets. you have to remove the heatsinks.
        Hello
        I have a problem with an acbel, I can't start it, I have changed almost all the capacitors including the 100uf 400v, but it doesn't want to start, you can tell me what I have to change since you know this power supply thanks. (on the other hand I managed to repair two samsung) now it has become a challenge between me and him
        • cheeky2
          • Dec 2012
          • 337
          #124
          Originally posted by cyclones
          Here are the photos as promised. Hopefully this will be helpful in the future.
          I know it's an old thread but thanks for the picture It ensured a quicker removal of the heatsink without any extra points being unsoldered.
          Found this thread very useful and aiding the quicker diagnosis of the failed PSU.
          Just parts to order now
          • cheeky2
            • Dec 2012
            • 337
            #125
            A successful repair was carried out with the help of this information contained within this thread.
            Just some advice the thermistor that is mounted on the heatsink is a right pain to solder in place. So I soldered some 3Amp fuse wire to both of the legs which is far thinner than the thermistor wire and used them as guides to pull the legs through the two holes to make the assembly of the heatsink far easier. This saved me a lot of time in trying to line up the wires of the thermistor. As if you don't both legs are near impossible to line up correctly blind and will just bend over as the heatsink is lowered into place.
            • bzyzny
              • Dec 2011
              • 4
              #126
              Just wanted to say thanks to everyone in this thread, and the other related threads on here. Recently I repaired one of these power supplies thanks to the info on here and the capacitor list found on thehouseofmoth dot com. I had to do some digging to find suitable replacements for some of the parts, since I couldn't find them in stock from a reputable source. Here's a list to hopefully help the next person. The bridge rectifier and mosfets have slightly different specifications but they worked for me. Please verify for yourself that they are correct replacement parts for your PSU.
              Digikey part numbers
              Fuse: 486-1767-ND
              Bridge Rectifier: GBU8JFS-ND
              Mosfets: 497-3263-5-ND
              Main cap (390uF 450V): 493-3238-ND
              • PantherDave
                by PantherDave
                Hi all!
                05-29-2024, 02:01 PM
              • GLISIT
                by GLISIT
                01-16-2025, 02:29 PM
                by sam_sam_sam
                03-31-2024, 02:12 PM
              • sew333
                Restore on AC power - question. Power outage and pc not booted again. But in power co
                by sew333
                Hi my pc: 10850K stock 4800mhz
                2x16 GB DDR4 GSKILL 3000mhz XMP
                Seasonic Tx-850 Ultra Titanium
                Gigabyte Rtx 3090 Gaming ( 2x8pin,2 separate pcie cables )
                Asus Z490 Maximus
                1 TB SSD
                Hi . I have an question. 5 days ago i had momentary power outage for brief moment. When power back pc not booted itself. I just presset reset button to turn on pc.
                In bios i have option RESTORE ON AC POWER - ON.
                But when i cut power by pressing off BUTTON on power cord for second and then turning on pc booting itself...
                01-05-2022, 08:13 PM
